2005 f150 4X4 what fluid for tranny/ifferential/trxfr case
Old 01-07-2008, 09:24 PM
peanstein's Avatar
ok, what do you recommend on a 2005 4X4 f150 for tranny/dfferential /ransfer case service?
i bought it used with 31K and now has 45K
i have only changed the oil and oil filter as well as the fule filter. oh air too.
i have not off roaded and occasionally engage the 4x4 for a minute or so to activate it only.
what should i do in respect to the fluids for the tranny/dfferential /ransfer case fluids? if replacement is recommended, what type should i use? nothing fancy needed. what filters, if any, should be replaced as well?
thanks and i have looked in the manual for recommnedations but would like others opinions that have done it.
thanks
victor
Old 01-07-2008, 10:05 PM
KDracing's Avatar
i have fluid types / specs from a 2000 F150 4x4 but they may not be the same, if you want them let me know. sorry i don't have info on 2005
you may want to pick up a service manual that will give you all specs / fluid types for your 2005, i have one on my 00
Old 01-07-2008, 10:19 PM
KDracing's Avatar
oops i double posted sorry site came up with server busy, and i hit post too many times, no idea why it took 10 mins to post again
Old 01-07-2008, 10:53 PM
Galaxy's Avatar
Amsoil ATF for tranny and transfer case. Amsoil 75W140 for the rear axle and 80W90 for the front. Don't forget to throw in a bottle of friction modifier in the rear axle.
Old 01-08-2008, 01:58 AM
Fifty150's Avatar
Royal Purple
Go to the website and/or give them a call.
Old 01-08-2008, 10:28 AM
peanstein's Avatar
will i have to replace all the fluids then at 50K miles?
thanks to all for the posts.
Old 01-08-2008, 12:51 PM
Diffs and transfer case should be good for 100k. Just keep the tranny fluid changed every 30k or so.
Old 01-08-2008, 08:09 PM
peanstein's Avatar
thanks but i think these guys got what i needed.
Old 01-20-2008, 07:34 PM
t3h1337r's Avatar
kd racing is the fluid list ya got the same as the 02's?. If so can ya list or pm them to me. later on
Old 01-21-2008, 10:27 AM
KDracing's Avatar
here is the fluids list, it says 97-03 so it should cover your 02
Transfer Case ------- MERCON ATF
Chasis Grease ------ SAE NLGI no. 2 grease
Differential (Front) ------- SAE 75W-90 GL-5 Gear Lubricant
Differential (rear) --------- SAE 75W-140 GL-5 Synthetic Gear Lubricant + Friction Modifier if Limited Slip
Capacities
Transfer Case ------ 2.0 qts
Front Diff ----- 3.6pts
Rear Diff --- 5.5 - 6.9pts (depending on which diff you have)
Friction Modifier add 4oz to 8.8 and 9.75
add 8oz to 10.25
Quick Reply: 2005 f150 4X4 what fluid for tranny/ifferential/trxfr case
