Recommended Transfer Case/Differential Interval Change
Old 01-12-2008, 10:54 PM
02SC4x4's Avatar
2004 F-150 5.4L 4x4 SC
i have tired in vain to find this out to no avail. the local mr. lube "recommended" 48000(km) for the front diff, and 96000(km) for the rear diff, and i forget what they recommended for the transfer case. the ford "Scheduled Maintence Guide" just tellls me the "recommended" type of fluid to be used.
Does anybody know what the recommended interval changes are in the front and rear diff and the transfer case?
its a bit off topic but does anybody know if its possible to get a selectable locker/LS differerential for the rear and FRONT?
thx
Old 01-13-2008, 01:58 AM
There is no specified interval except under severe service conditions. I'd recommend every 100k miles.
Old 01-13-2008, 10:38 AM
4wd150's Avatar
yea i had all that just changed now at 98000
Old 01-15-2008, 06:45 PM
KDracing's Avatar
directly from ford
TRANSFER CASE - EVERY 60,000
DIFF - EVERY 30,000 ***** REMEMBER FRICTION MODIFIER FOR FLUID CHANGE
Old 01-15-2008, 07:43 PM
tnsilverfx4's Avatar
"its a bit off topic but does anybody know if its possible to get a selectable locker/LS differerential for the rear and FRONT?
thx"
Front:
LS- Auburn, Trutrac, maybe eaton posi, ford traclok
Selectable locker- Eaton Elocker, Auburn ECTED, ARB airlocker
Auto Locker- Detroit Locker
9.75 Rear:
LS-Auburn, Trutrac, Traclok, eaton posi
Selectable Locker- N/A
8.8 Rear:
LS- Auburn, Trutrac, Traclok, eaton posi
Selectable Locker- Eaton Elocker, Auburn ECTED, OX, maybe ARB
That should be accurate. Correct me if I'm wrong. I'm not including Ezlockers or any of those insert units.
Ive got an ECTED getting installed up front next week
Old 01-16-2008, 01:52 AM
KDracing, I believe those are severe service intervals.
Old 01-16-2008, 11:05 AM
SAJEFFC's Avatar
A word to the wise on the transfer case fluid. I just had mine changed at 31k miles and it looked a little rough. The fluid was definitely brownish and dirty. Now I am the most **** person on here about my truck....it is waaay over maintained! The truck probably has a total of 50 miles in four wheel drive. I was surprised for sure about the condition of the fluid. The book says use Mercon in it but that has been replaced with Mercon V now according to Ford. Think I will do it every 30k along with the tranny fluid from now on.
Old 01-16-2008, 11:47 PM
02SC4x4's Avatar
i heard rumours about the rear diff @ 96000(km) and the front diff and transfer case @ 48000(km), apparently the front needs it more often due to the fact that it doesnt get used as much.
so if youve only put 50 miles on the transfer case the fluid just sat and settled for its entire life(almost)
Old 01-17-2008, 08:12 AM
SAJEFFC's Avatar
No not really. Most people don't realize that part of the transfer case is spinning even when in two wheel drive. Remember the output shaft of the tranny goes through the transfer case and on to the driveshaft. The T-case has its own oil pump for lubrication. I think probably the T-case fluid runs hotter (no coolers) and breaks down sooner than the transmission fluid. Anyway, at least its dirt cheap and easy to change.
Old 06-13-2015, 06:48 PM
mikelcurtis's Avatar
mikelcurtis
thx
I went with the ARB lockers for the front & rear of my 05 F150, works fantastic! I like the added bonus of having the ARB compressor as well. I changed my gear ratio to 456s while we were in there. For transfer case, I always go with Royal Purple Max ATF. Around 2 quarts does the deal, get a little hand pump for the fill, their really cheap and make the process much easier.
Quick Reply: Recommended Transfer Case/Differential Interval Change
