procharger 8 rib belt???
Old 01-20-2008, 01:08 PM
anybody convert thier procharger to run an 8 rib belt?
Old 01-20-2008, 07:14 PM
CDB03STX's Avatar
Yeah, inspiring minds want to know
Old 01-20-2008, 07:54 PM
ganiman's Avatar
ONELOWF did it, heres a pic from his gallery.Its a different head unit,but the same apllies to us.
When I up my boost (if this motor will ever let loose) I plan to run 15-17 psi and the 8 rib is a must.
Old 01-20-2008, 08:23 PM
CDB03STX's Avatar
What would you have to do about the tensioner on the P-chargers? Did he have someone personally turn the pullies or is there a company that makes them?
Old 01-21-2008, 12:27 AM
they make 8 rib head pulleys for P1SC and F1's, I would just modify a tensioner to fit and then we'd have the option to use lightning / harley lower crank pulleys
either way with the low restriction intake I've got coming (CDB03STX is getting the first one) and this possibility of the 8 rib belt setup I may be able to offer complete bolt in upgrade kits
Old 01-21-2008, 12:40 AM
ONELOWF's Avatar
It looks like the tensioner is the most difficult to modify as it runs the belt between the mounting plate and the tensioner arm.. If you can buy one far an 8 rib, then the rest will be just pulley changes.
Here's a photo of WLF's Powerdyne 6 rib set up with the ATI tensioner. This is where I got the idea for the Paxton set up I made.
[IMG][/IMG]
Old 01-21-2008, 12:42 AM
i found the 8 rib parts that ATI makes for another ford kit and I will get part numbers and prices tomorrow
Old 01-22-2008, 08:58 AM
JMC's Avatar
JMC
JMC is offline
I am curious as to why you want an 8 rib belt.
JMC
Old 01-22-2008, 01:32 PM
CDB03STX's Avatar
JMC
Belt slippage would be my only concern. I know some have added another idler pulley which gives more "wrap around" across the charger pulley. An 8 rib maybe overkill for 12 lbs.
Do you have any slipping problems?
CDB03STX
Old 01-22-2008, 02:01 PM
JMC's Avatar
JMC
JMC is offline
CDB03STX
No belt slip so far.
JMC
Old 01-22-2008, 04:41 PM
so i can run interchangeable crank pullies designed for the lightning/harley trucks...
my new engine will running close to 18psi
Old 01-22-2008, 05:22 PM
mrpositraction's Avatar
I don't see why not. Man, 18 psi is going to rip. Will the S/C produce/sustain that much?
Old 01-22-2008, 06:08 PM
CDB03STX's Avatar
ATI says it will
P-1SC
Max Supercharged HP---825
Base HP Range of Motor---200-500
(Naturally Aspirated)
Max Flow (cfm)---1200
Max boost (psi)---30
Old 01-22-2008, 06:18 PM
justjames80's Avatar
Not with the belt setup ATI uses on these trucks. 12# pulley with the shift points dialed up can cause some mild orbiting of the belt which causes a bit of slippage. You wouldn't notice it by looking at the gauge but it shows up when datalogged. An 8-rib pulley setup would be ideal with a 12# pulley and I would love to find a cost effective way to do one.
Old 01-22-2008, 07:18 PM
jbravo316's Avatar
My P1 procharger starts slipping shortly after I tighten it back up. I want more boost, but my tuner says it is spinning as fast as it can and be effecient. It shows 13 lbs or more, so what head unit would I need for about 15 to 20 lbs of boost depending on what size pulley is on it? Then I would sure want a 8 rib belt, or go to a cog system.
Quick Reply: procharger 8 rib belt???
