Torsion Key lift kits????
Old 01-22-2008, 09:52 PM
97f150junkie's Avatar
they sound like a good and cheap lift!! i would love to know where i can get one that would lift my truck about 2.5 to 3 inches. does anyone know i good place to get them???
Old 01-22-2008, 10:19 PM
keith_bennett's Avatar
If i did, i wouldnt tell you. They are absolute junk. They will put way to much preload on the torsion bars, causing premature wear of parts. Crank the oem torsion bars for the same lift without the horrible preload.
Old 01-22-2008, 10:21 PM
JakeO's Avatar
Exactly.
Old 01-22-2008, 11:45 PM
alsupercab's Avatar
there is no way he is going to get 3" out of them
Old 01-23-2008, 01:05 AM
4.2trimble's Avatar
Theres no way he's gonna want 3" out of them! Keys or no keys! just crank up the torsion bars to the top the crank them back down 2 complete turns this will give you more than level and you can clear up to 33" tires! why pay the money for something you can do for free? plus all the extra money that you have to spend when your CV joins and ball joints go in the crapper because the bad angles! just my .02
Old 01-23-2008, 09:39 AM
jk007's Avatar
They are garbage. Crank your torsion bars for free if you have a 4x4. If you have a 4x2 then you need a leveling kit.
Old 01-23-2008, 12:49 PM
wandell's Avatar
I agree.
Old 11-20-2008, 04:52 PM
Upon39s's Avatar
torsion lift
i put aftermarket keys on mine.. they work great.. 40k miles on them w/o any issues.they were cheap too less than $75 delivered at wheelsnparts.com
dave
Old 11-20-2008, 05:27 PM
jasearmy's Avatar
so everybody seems to think cranking up the oem torsion bars are the way to go rather than buying a leveling kit or aftermarket keys
Old 11-20-2008, 10:32 PM
wandell's Avatar
dave
You still paid $75 for something you could have done for free.
Old 11-30-2008, 08:59 PM
FX4 by 4's Avatar
Torsion lift keys
I have a 2002 FX4 F150, I've maxed the torsion keys. Does this model come with a lift key already installed or will a lift key add more height. Other option: take the existing torsion key off and rotate it one notch then re-insert and lift again. Does this work???
Old 11-30-2008, 09:39 PM
wandell's Avatar
Welcome to the site.
Yes, your truck has torsion bars and the oem keys are adjustable. The aftermarket keys are indexed differently so you can crank more preload onto the torsion bars than you can with the oem keys. The problem is they let you put too much preload on the torsion bars. This destroys your ride quality and puts your CV and ball joints at extreme angles which leads to premature failure. Just crank up your torsion bars with your oem adjustment keys enough to level your truck and get an alignment. If you want more ride height, add a full suspension lift or a body lift.
Old 01-23-2009, 08:41 PM
Craig Stickney's Avatar
97 F150 Torsion Key Lift
You can get the Forged Torsion keys from Truck Xessories 800 772-3731. They sell them for $125.00 / pair. Daystar Part No. KF09120.
The right torsion key will give you 2 inches of lift with any additional pre-load. They are re-indicated so they require the same amount of tension on your torsion bar as your stock torsion key. You will need to re-align the front end. Hope this helps.
Old 01-23-2009, 10:01 PM
wandell's Avatar
Actually no, spam never helps.
Old 02-11-2009, 02:48 PM
RedOak's Avatar
Can I crank my OEM torsion bars down to lower my 2000 Expedition
Quick Reply: Torsion Key lift kits????
