Default keypad code location
Old 02-17-2008, 10:15 AM
stick-move's Avatar
Smile Default keypad code location
Im trying to find the location of the default door keypad code, I beleive its located on a computer module somewhere. The truck is a 2001 Ford F150 Lariat 4x4 Supercrew, 5.4L, AT. Thanks....
Old 02-17-2008, 10:36 AM
torkum's Avatar
It should be in a small plastic sleeve in the back of your owners manual black zipped pouch. White card almost the size of a credit card with the FORD logo and a five digit number in box printed on it.
Old 02-17-2008, 03:48 PM
freshjive_05's Avatar
you wouldnt happen to know if its stamped somewhere in a 2004 fx4 would you? i bought the truck and came with no manual, and ford told me it would take them 30 minutes to download it out of the truck.. i dont know if i want to believe that
Old 02-17-2008, 03:59 PM
kd4crs's Avatar
Your master code is printed on the sticker attached to the VSM on the rear wall of the cab behind the driver's seat. The dealer can get it for you but they like to charge you for th privilege.
Old 02-17-2008, 04:41 PM
hey thanks alot, they told me before about getting it from the computer it would be minimum of 50 bucks, so we will see. thanks again
Old 02-18-2008, 12:25 AM
SSCULLY's Avatar
Originally Posted by stick-move
Im trying to the location of the default door keypad code, I beleive its located on a computer module somewhere. The truck is a 2001 Ford F150 Lariat 4x4 Supercrew, 5.4L, AT. Thanks....
A Quick search would have produced 63 threads, one of which :
https://www.f150online.com/forums/sh...d.php?t=319924
Show the location to find the RAP Module, which has the factory code on it.
Old 02-18-2008, 12:28 AM
SSCULLY's Avatar
Search would turn up a few threads on the topic for the 2004 ( non heritage ) + MY Trucks.
I put together a write up on the rear seat removal process from a few members :
Right click -> Save As:
http://my.voyager.net/~sscully/04and...eatremoval.doc
Old 02-18-2008, 01:48 AM
joshmac4.6's Avatar
Any dealer with the IDS or WDS can tell you the code, I could access the code in less than 5 mins, 30 mins is B.S.
Old 02-18-2008, 07:56 AM
stick-move's Avatar
I looked and I dont have the card with the code, and Im sure Ford will want 100.00. I was trying to save a buck . Any other ideas ?
Old 02-18-2008, 09:45 PM
bdungrimes's Avatar
You can look under the dash where your gas and brake is. If it is like mine there will be a plastic piece up ther somewhere with five numbers and that should be it.
Quick Reply: Default keypad code location
