Idle adjustment 4.6.V8
Old 04-19-2008, 05:54 PM
fatjap44's Avatar
Hi fella's just a quicky
My 97 F150 4.6 idle speed seems to be set high ...the engine seems to settle at around 1000-1100 rpm ....can anyone tell me how so slow it down a bit to a reasonable level?
Also as i'm in the UK where can I source service items filters belts etc.
Are front A bars available for these trucks ?
where would i purchase a sports silencer just to improve the exhaust note a bit.
many thanks
Old 04-19-2008, 08:18 PM
jethat's Avatar
There is no Idle adjustment. You need to clean or replace the Idle air control or IAC its located behind the throttle body.
Old 04-20-2008, 06:37 AM
FordTech1's Avatar
You should also check all of the rubber hoses for any tears/breaks....unmetered air (vacuum leak) will cause a higher idle as well......
Old 04-20-2008, 08:05 AM
Tumba's Avatar
Most of the time it is a vaccumn leak, But star by cleaning the IAC. The first flace to check for the vac leak is the pcv tube and its connector at the intake
Old 04-20-2008, 11:04 AM
NYfordguy's Avatar
My truck has no vac leaks and it still seams to idle...a little high...close to 900 maybe 1000..
Old 04-20-2008, 11:09 AM
joshmac4.6's Avatar
Did you clean the IAC?
Old 04-20-2008, 06:48 PM
fatjap44's Avatar
Idle
Thanks fella's for the info i'll have a go at cleaning the IAC and check the hoses and let you know
many thanks fatjap44
Old 04-20-2008, 09:19 PM
NYfordguy's Avatar
I've clean my IAC like 5 times in under 500 miles! I've even cleaned it two times after the no idle change!
Time for a new one?! Original 1997 one.
Quick Reply: Idle adjustment 4.6.V8
