04 Supercrew Shift Knob Removal
Old 05-12-2008, 03:42 PM
jgj10's Avatar
04 Supercrew Shift **** Removal
I had the chrome cover pop off. And you have to buy the ENTIRE shift **** to replace the top.
I have searched and cannot find removal instructions for the shift ****. I'm referring to the gray and chrome part.
Any ideas -- thanks in advance.
Old 06-06-2008, 07:25 PM
tdpwildcat's Avatar
The same thing happend to mine. I used a little supper glue on a toothpick and it seems to fit and hold better then when it was new. Just be careful b/c the supper glue will ruin the rest of the ****.
Old 08-19-2008, 12:20 PM
justinbustin's Avatar
shift **** replacement 04 f150
This is crap! There are no instructions anywhere for this. Plus when you buy the 75$ part it comes with no instructions. Is there anyone out there who has advice, no glue, I would like to see the right way to do it.
Old 08-27-2008, 10:57 PM
2004 f150 shift ****
Seriously, At least...is there anyone out there that knows how to remove it without breaking it. This is the center console fx4 version??????????
Old 08-28-2008, 11:00 PM
danbabc's Avatar
Same problem with a 2004 F-150 Lariat scab. I have the replacement **** (4L3Z7213BA) but am a little reluctant to beat the crap out of the broken one to remove it from the shifter assembly. It looks like the **** slips on but is not easy on easy off.
Old 09-01-2008, 07:16 PM
lll
Old 09-01-2008, 09:15 PM
http://i38.photobucket.com/albums/e1...ithscrewdr.jpg
1st pry down on the chrome piece, be careful not to damage it.
http://i38.photobucket.com/albums/e1...xposethisb.jpg
2nd prying down chrome will expose this blk plastic piece, you must also pry this down I would use two large screwdrivers one on each side
http://i38.photobucket.com/albums/e1...Ihadtoslig.jpg
3rd it should pull up and off I had to slightly mangle it...hey I a guy this how we fix stuff
http://i38.photobucket.com/albums/e1...nthespring.jpg
4th ensure that you maintain the spring
More to Follow
Old 09-01-2008, 09:19 PM
2005 f150 shift **** part II
http://i38.photobucket.com/albums/e1...tothecrome.jpg
5th slide this piece down into the chrome piece below it
http://i38.photobucket.com/albums/e1...inlikethis.jpg
6th it should sit in like this
http://i38.photobucket.com/albums/e1...enewshiftk.jpg
7th line up and slide down the new shift ****, be careful of the spring it can caught up inside, so go straight down & it should slide down snuggly
MORE TO FOLLOW
Old 09-01-2008, 09:22 PM
2004 f150 shift **** Part III
http://i38.photobucket.com/albums/e1...ethattheta.jpg
8th once you have on make sure that the tabs line up with the lower black pieces open parts
http://i38.photobucket.com/albums/e1...slidethebo.jpg
9th then all you have to do is slide the bottom up to meet the top and you’re good to go.
Hope this helps everyone!!
Old 09-01-2008, 09:30 PM
Now you can also just suck it up and buy the $60-$70 dollar handle and carefully pry off the top chrome piece and stick it on your exsisting ****. I also tried this just to see if worked and it did. I used the sharp edge of a Knife to pry it.
Old 02-25-2009, 09:34 AM
BARRIERE's Avatar
Barriere
You dont have to replace the whole shift handle use part num 4l3z7213ba fpr 2004
Old 09-15-2009, 10:22 PM
red69viper's Avatar
anybody know any aftermarket shift ***** that fit. i got my stock one off and it broke coming off and the one i bought ,..... http://www.amazon.com/dp/B000HTS5JC/...SIN=B000HTS5JC .... doesnt seem to fit right.
Old 07-21-2011, 01:51 PM
Neurotoxin's Avatar
Very useful thread and how-to! Thanks!
I had to change my handle because the mechanism in the button broke (wore out and one of the pins fell out).....I had to purchase the whole handle together to replace just the button. This how-to was perfect.
Also, my shift interlock switch is acting up/not working at all at times so while working on the handle I took the liberty of effectively bypassing the switch using the white button on it's side. I pushed it down, placed a screw in the open void (to not allow for the button to come back up) and taped it to ensure the screw doesn't fall out. Works like a charm now and I don't have to spend 75$ on a switch
Thanks again!
Old 02-03-2012, 12:01 AM
tvoth33's Avatar
Thanks for the instructions and pics
I broke the cap off my shifter a few days ago. I purchased a new shift handle on Ebay. The note about the spring made all the difference for me. In the process of removing the old handle the spring was stuck up inside it. I was able to tap it out and install the new handle with no problem following your set of instructions. Thanks, again.
Old 03-07-2014, 02:55 PM
junior999's Avatar
I just finished replacing my shifter **** assy...basically, pulling out the button disengages the shifter **** assy from the shifter and once this is accomplished, the only thing holding the shifter **** assy on is the plastic 4-tab compression connection (shown in 7th "step" above)...this is what worked for me:
Leaving the shifter in "Park" position, I was able to get more space between button and shifter when pulling button out. Just enough space that I slid the Red "tool" (that came with the new one), into the created space and with a little pulling out of button, was able to get the button to "travel" freely like the NEW shifter assy. If you look down into the NEW shifter assy, you will see a rod/pin that pulls up(actually down when in operational position) and out of view when pulling button out from assy, essentially disengaging shifter **** from shifter. With some extra "up" pressure on shifter **** assy, the assy came off intact. I installed the NEW one in reverse order and had a little rougher time than expected reengaging the button to operate correctly, but it eventually pressed into place. My educated guess is that you need to (while pressing in on button) carefully/slightly pull up on shifter **** assy to help maybe increase some space for the rod/pin to get pushed back down into proper position in shifter.
Quick Reply: 04 Supercrew Shift Knob Removal
