6-Disc CD Changer problems
Old 06-18-1999, 08:21 PM
MAK 3's Avatar
I have recently purchased a '97 F150 Lariat 4x4 and it came with the stock 6-disc changer. When I bought it the magazine was not in the changer and they did not have one on hand. Today I finally got the magazine and rushed home loaded it with CD's and inserted into the changer, punched *CD* on the stereo and it said *NO J* (the same thing it did when the magazine wasn't in the changer)...so I punched the button on the changer to try and eject the magazine and got nothing! I checked all the fuses and none were blown, all the visible wires are hooked up and I'm stumped! I called the dealer and they're gonna take a look, but does anyone in F150land know what might be going on???
MAK
'97 F150 Lariat 4x4, 4.6L V8, 3.55 LS, "The Green Monster"
Old 06-18-1999, 08:24 PM
MAK 3's Avatar
The stereo said *NO - DJ* - I don't know how I got that little smiley face. Thanks
Old 06-18-1999, 08:54 PM
JA_Stang86's Avatar
There should be a mechanical release on the changer. Look for a small hole on the front about the size of a paper clip. Then make sure the CD's are in the proper direction (label up or down). Good luck
Jeff
1999 F150 Lariat
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield, VentVisors, Class III hitch, Ford molded mud guards, soft tonneau
Old 06-18-1999, 09:16 PM
MAK 3's Avatar
JA_Stang-
I found a hole on the front under a black circular sticker but it did not appear to be the "release" you were talking about. I really didn't want to stick anything in there and by looking it doesn't have anything you would push, switch or release. Help???
Old 06-19-1999, 01:37 PM
ARKF150's Avatar
I noticed on a 99 Taurus with factory radio with CD button, but no changer attached, that the "NO DJ" would show up. I have had problems with my 97 F150 6 disc changer, but it only says "NO CD" when it can not read the disc. Possibly you have no connection or bad connection from head unit to changer.
Alan
97 XLT S/C 4.6L Black 4X2, tint, BugII, Lund Tonneau, DrawTite Hitch, Pioneer speakers, Manik S/S Nerfs and Pilot Driving lights(on the way)
Old 06-19-1999, 03:31 PM
JA_Stang86's Avatar
You probably will not see any switch or anything, it will have a mechanical release button inside. You won't need much force, gently press straight down. You should feel it move, if not then you may have the wrong hole. I'm not positive they have one, my truck is out so I can't check. Good luck
Jeff
1999 F150 Lariat
5.4L 3.55ls
Old 06-21-1999, 04:23 PM
Tim A's Avatar
The radio is saying "No DJ" because it thinks the cd changer (or CD disc jockey as we like to call it) is not there. The wiring harness to the DJ may be disconnected. Since you said the magazine wouldn't eject, it probably doesn't have power going to it. The dealer should be able to remove the DJ and check the harness for you.
Old 06-23-1999, 01:10 PM
MAK 3's Avatar
Got the truck checked out and it was a loose wire. No Harm, No Foul. Just a little pain in the a**.
Works great now! They told me its a JVC changer, is this true?
Old 06-23-1999, 03:07 PM
Tim A's Avatar
Assuming you have the factory installed changer, it is a Clarion.
Old 06-23-1999, 09:18 PM
ARKF150's Avatar
While replacing rear speakers I noted the CD changer had a sticker with Clarion on it. I have a 97 SC 4X2
Alan
97 XLT S/C 4.6L Black 4X2, Tint, BugII, Lund Tonneau, DrawTite Hitch, Pioneer speakers, Manik S/S Nerfs and Pilot Driving lights(on the way)
Old 06-26-1999, 05:56 AM
Hitmanhite's Avatar
Hey Mac,
Where did you get the magazine, and how much? I want to get about three extra ones.
97 F-150 Lariat, 5.4 Triton V-8, Westin Nerfs,
K&N, Leather, ect., ect.
Old 07-03-1999, 10:15 PM
MAK 3's Avatar
Because the Truck did not have one in it (6-disc magazine) when I purchased it the dealership got one for me for FREE! But it took them almost 2 weeks to get it and it's pretty cheap (quality). When I inquired as to buying extra ones they told me they cost about $20 (which means they're probably $29.99) - just call your dealer, then ask where else you can get one (for 1/2 the price!!!)
MAK
[This message has been edited by MAK 3 (edited 07-03-1999).]
Old 04-10-2014, 09:41 PM
D Thomas's Avatar
Same problem on my trunk mounted unit...
Same problem on my trunk mounted unit, any other fixes? Want to troubleshoot before i attempt to take to a dealer, it is a '99. Fuses look fine, as well as the wires, any input would be appreciated.
Quick Reply: 6-Disc CD Changer problems
