How tough to replace caliper on 2004 FX4?
Looking for any good instruction on how to replace a left rear caliper on my FX4.
Is it as simple as removing the 1 bolt and putting the new one on? I am having to replace because I sheared off the friggin bleeder valve. I am going to try and back it out, but thought I would get a jump on instruction on removing rear caliper.
Thanks in advance!
Thanks in advance!
Yeah. It's shear off flush with the caliper. I'm going to try and back it out with some bits that I have. If that doesn't work I am looking at installing a new caliper.
Luckily though the bleeder never opened and I can still drive around.
As far as I can tell the rears look very simple. I connection on the caliper.
Didn't know if there were any gotchas in replacing these.
some heat and a easy out bit will probably do the trick. soak it in p.b blaster beforehand.if they are like the 97-03 calipers should be pretty easy. id try to get that bleeder out first though. a new bleeder screw is alot cheaper than a caliper so....
