how to adjust ignition timing 1994 4.9
Old 08-07-2008, 12:05 AM
GAZ1984's Avatar
how do you adjust the ignition timing on my 4.9 1994 f150? im getting an error saying spout circuit open and it runs like a 3 legged pig. anyone had this before?
thanks
Old 08-07-2008, 12:34 AM
Paralyzer's Avatar
the spout connector is a 2 wire conector near the dist. that looks like it has a "cap" on it. the cap is pretty much a jumper. if this circuit is open it will run on base timing. check that connector and the wiring to it first.
edit: the spout may also be by the drivers side hood hinge i cant remember...
Old 08-07-2008, 04:44 PM
GAZ1984's Avatar
thanks mate. ive sorted the timing and still ran rough.i noticed plug 2 was sooty and others were worn out so replaced plugs rotor cap and leads. cylinder 2 is not firing but has a spark. the plug is sooty but not wet so now starting to wonder if its the injector. i dont own a compression tester but she sounds ok on a polish test.
is injectors a common problem with these trucks?
thanks for your help
Quick Reply: how to adjust ignition timing 1994 4.9
