My 4x4 F150 hub/bearing replacement how too.
Old 09-24-2008, 03:32 PM
Dans4x4F150's Avatar
My truck is a 98 f150 4x4 and i just replaced my left front hub bearing and threw this together for yall. Not saying it is 100% but it is basic so you can get it done. I have never done this b4 and it only took me 30mins
Truck in shop
POP center cap off
Remove carter pin and cover
Old 09-24-2008, 03:33 PM
This is what it should look like showing 36mm bolt
Break it loose when truck on ground and remover bolt. After you do that jack truck up and pull tire.
Remove caliper the 2-13mm caliper bolts and slide caliper and take off break pads.
Old 09-24-2008, 03:34 PM
Then remove the caliper mount by removing the 2-18mm bolts holding it on. After you have that remove slide the caliper mount off
Then remove the heat shield so you can see better by removing the 3-8mm bolts
Then Remove the 3-15mm bolts holding the hub on and slide the hub off
Old 09-24-2008, 03:39 PM
It should look like this
The new one and repeat everything you did to put it back together using loctite on your bolts. Verry simple i hope this somewhat helps.
Old 09-24-2008, 03:43 PM
If someone whats to add torque specs please do. I just he maned them LOL
Old 09-25-2008, 06:37 PM
Is this sticky worthy?
Old 10-02-2008, 01:21 AM
defconfive's Avatar
Registered User
Interesting post.
I replaced the front hubs on a '04 Silverado 2500 HD this summer at the dairy I work for. It was basically the same thing, but there are 4 bolts mounting a very different hub assembly on. Cool to see the difference in the design.
Old 10-15-2008, 10:38 AM
yup most are about the same its really easy
Old 11-04-2009, 08:56 AM
StumpZ's Avatar
Awesome post! Took my fear out of doing it myself. Thanks!!
Quick Reply: My 4x4 F150 hub/bearing replacement how too.
