o2 sensor location question
Old 10-24-2008, 07:04 AM
samatic's Avatar
Lightbulb o2 sensor location question
This is my first post so go easy...
I have a 2002 F150 Supercrew Lariat 5.4l....
Long story short, I need to replace the o2 sensor on the Bank 1 Sensor 1.
My question is which side is that on? I know its before the cat, but on the drivers side or the passenger side? Thanks in advance...
Old 10-24-2008, 08:27 AM
Quintin's Avatar
Passenger's side.
Old 10-24-2008, 08:48 AM
projectSHO89's Avatar
.. and a real PITA to access if 4 X 4. Go in through the wheelwell after safely removing the wheel and liner.
Steve
Old 10-24-2008, 03:20 PM
samatic's Avatar
Thanks.... Yes it's a 4x4, so thanks for the PITA warning.... It figures....It's like 15deg outside, I am in anchorage. I plan on doing the job here in a few hours so I will let you all know....
Old 10-24-2008, 09:15 PM
samatic's Avatar
JOB DONE!!!
I had to remove the passenger side wheel to get access to it and the stooopid special socket the parts store talked me into buying didn't do me a bit of good. I completed the job with only a 7/8 combo and small flattip. The hardest part was disconnecting the wires cause it was up in there and kept moving around. It took me about 1 1/2 hours to complete, probaly because it was my first time. Thank you for helping...
Old 10-24-2008, 09:22 PM
jbrew's Avatar
The tool looks like this for these trucks -
Old 10-25-2008, 01:47 AM
samatic's Avatar
The back 2 were very easily accessible, but the front 2 are so crammed in there that I dont think that tool would work with as little space as there is. But thanks anyways... hopefully I won't have to do that again for a long long time...
Old 10-25-2008, 02:16 AM
jbrew's Avatar
Do it the hard way, I don't care. Everyone I know that uses that tool has NO problems - especially on the passenger side. I wouldn't expect you to know jack, but don't knock until you try it. The 7/8 or 22mm have stripped O2's in the past. This tool slides directly over the passenger side O2 sensor thru the passenger side wheel well allowing you to attach a breaker bar to it.
You don't know what your talking about. This is the tool for the job.
Old 10-25-2008, 02:21 AM
jbrew's Avatar
edit
Old 10-25-2008, 05:41 AM
samatic's Avatar
wow... are you serious? You flew off the rocker on that subject... I never meant to come across the way you obviously took it. I know I am a amature and was simply stating my opinion and I know I don't know jack, otherwise I wouldnt be here asking for help. But thank you for pointing that out and acting like the true professional you are. G'day
Old 10-25-2008, 06:07 AM
jbrew's Avatar
I wouldn't have posted something that does not work . If you came here to learn, - Don't think - listen.
Old 10-25-2008, 07:17 AM
samatic's Avatar
ok, So....Don't think, just listen? Because this place has nothing to do with thinking for yourself, because apparently you know everything there is to know about everything. I got it, from now on I will let you handle everything....thanks pal
Didn't mean to make you mad to begin with but, I guess if I was a "tool" I would have gotten mad also...
Old 10-25-2008, 08:28 AM
Quintin's Avatar
I ain't got a dog in this fight, except that for the longest time, I never owned any kind of special O2 sensor socket or wrench. And I do this stuff for a living. I used a 22mm open end wrench on just about everything, until I took on a new car line at work that requires the socket, since the sensor is recessed slightly into the exhaust manifold to where a combination wrench won't fit on it. I still use a 22mm open end wrench on just about everything Ford.
There is no ultimate right or wrong, IMO, it's whatever works.
Old 10-25-2008, 09:40 AM
jbrew's Avatar
I dont think that tool would work with as little space as there is..
You said this after I post the proper tool for the job. Your telling me that I don't know what I'm talking about.
I couldn't remove the rears on the truck with a wrench - I had to get the tool.
Since then , it's allot easier using the tool. AGAIN - I wouldn't post something that does not work ..
Old 10-25-2008, 03:21 PM
samatic's Avatar
I get it... You wouldn't post something that wouldn't work. I understand that, and I thank you for your advice and expertise. I was just simply saying that in my opinion it looks like a tight space but, I am sure if I had the special tool you posted, it might be a diffrent story. What I can't figure out is why you got so defensive/agressive over a comment made by someone who is obvioulsy new here, aren't you supposed to be the pro? Wouldn't it be more benificial if you acted the part...
Quick Reply: o2 sensor location question
