How to take off tensioner pulley?
Old 11-15-2008, 10:10 PM
willys5555's Avatar
My truck has been making a sqeaking noise lately and it is getting worse. so i opened the hood and it appeared to be coming from either the idler pulley or the tensioner pulley. so i decided to replace the idler pulley today because it was easy to get to (except when i put the belt back on, it was off a little bit and broke so i had to spend an extra $40 ). but the noise is still there so it has to be the tensioner pulley. and after reading on here i used a mechanics stethascope and it is definatly the tensioner. i just cant figure out how to get the tensioner pulley out. i have a 1997 f150 with the 4.6. does the whole thing come off as an assembly? there is no nut on it where i can see right now. i saw several bolts all around the whole assembly...are those the ones i have to take off to replace the tensioner pulley? if someone has a drawing of how to get it off or even pictures, that would be amazing.
Old 11-16-2008, 02:06 AM
Blown F-150's Avatar
I'm not sure about the 4.6, but it should be the same as my 5.4. There are three 10mm bolts that hold the entire assembly to the front of the motor. once you pull it out you will see the bolt that holds the pulley it self onto the tensioner is on the "engine side", I think mine was a 13mm head on the bolt and it came off pretty easy just like the idler pulley. Make sure when you get the replacement it's the same diameter as the one on the tensioner. the idler pulley is larger than the one on the tensioner and I have been handed the wrong one from the autoparts store. You should also just be able to get the replacement bearing instead of the entire pulley.
I just had the same issue and it turned out to be the alternator bearing.
Good luck.
Old 11-16-2008, 03:24 AM
FRod's Avatar
3 bolts on the front of the assembly...thats it, comes right off. ALTHOUGH, i garuntee you its your idler pulley, they are $13 bucks at your local parts store, if not, less. They are very very commmen, in fact i just replaced mine. Just take the center bolt out and it comes off. You can even take the belt off, spin the pulley with your hand freely and you can hear a faint squeel, than its it, they should not make any noise at all and should be snug, not loose. Go try that i bet you will find your answer!
Old 11-16-2008, 03:49 AM
Neal's Avatar
Cool
HI!... Just repack the bearing. Or you can go down to your local bearing supplier and get a replacement high speed bearing for like $5. It's a waste to change the idler pulley. The pulley on the belt tensioner is not sold separately. It only comes with the tensioner. I tried to buy one from the ford dealership years ago.
Old 11-16-2008, 03:51 AM
Neal's Avatar
Cool
HI!... The bearings in the pulleys are easy to swap out.
Old 11-16-2008, 08:25 AM
Tumba's Avatar
The first one I changed, I went ahead and bought the whole assembly, and replaced it.
I then bought a replacement bearing for the old one at a local Applied industries bearing
supply. The bearing from there is a better quality. I used that one about six months later
on another F150. It's conveniant to buy the whole assembly if you don't do this as a hobby.
In Neals picture you just insert a 1/2" breakover handle to release the tension to flip the belt off.
Just get it back in the right grooves as not to damage it.
Old 11-16-2008, 12:07 PM
willys5555's Avatar
already changed the idler pulley...it still makes the noise. it is the pulley on the tensioner. and the idler pulley was $30.
Old 11-16-2008, 12:09 PM
willys5555's Avatar
Good luck.
i used a "mechanics stethascope and have determined that it is the tensioner pulley. but if i just replace the bearing...wouldnt i need a press and everything to get it out?
Old 11-16-2008, 12:32 PM
jbrew's Avatar
What a coincidence , I was going to start a new thread on this. I just removed mine last night real quick. I have some on the way - Gates tensioner w/pulley/ Gates idler/ new clutch fan/Gates belt/ new HP Fan (plastic).
Thing is, I 'm not sure if the gates tensioner is going to right one. They list that it is, but their picture of it isn't right. I need the tensioner replaced because the aluminum posts the pulley sits on are wore.
I have a quarter million miles + on this tensioner and pulley's w/ black colored bearings. The bearings are tight, but noisy as hell!!
The pulley w/orange colored bearing has 60k on it and it came from an explorer, but it's quiet, not one peep. That's what I'm after as far as the idler goes....Tensioners another story.
Suggestions ? I'll send what I have coming back if there's a better route. - I want the GOOD SH^T - Spare no expense
Thanks , brew
Old 11-16-2008, 12:37 PM
jbrew's Avatar
Yea , you need a tensioner. I did the same thing with a stethoscope/ plus I have it here in front of me - same deal - It's loud as f^ck. - BUT! The bearings tight..?
Tensioners wore.
Old 11-16-2008, 12:47 PM
jbrew's Avatar
Anyone know if the Visteon is any good?
http://www.autopartswarehouse.com/se...5608+1616+5919
Heres the one that will be here tues/weds - The Gates I ordered -
http://www.autopartswarehouse.com/se...20Ford%20F-150
Is DAYCO any good ? -
Old 11-16-2008, 03:02 PM
willys5555's Avatar
ok guys i got it fixed and it makes no more noise!! after several issues of course. haha
so i took off the tensioner assembly and it was clearly that pulley. it would grind horribly in my hand. and my original plan was that if the pulleys were the same size, i would put the new idler pulley on the tensioner and the old one back where it is since it was fine. that way the older one was in an easier to acces location. but come to find out they were different sizes so i tried popping out the bearing off the old idler to put it in the tensioner but i messed up the bearings in the process. so i went to the auto parts store and asked for just the bearing and they didnt have that so i had to buy the whole pulley. so i come home to put it all together, get it on the truck and start it up...it makes a horrible sound way different than before. so i assumed it was the belt(because i blew up a belt the night before) but everything seemed fine. so i take off the belt and reach down and the tensioner pulley is rubbing on the block. so i assumed they had gived me the wrong one. so everything came off again. but the pulleys were the same size. but i figured out that we had put the pulley on backwards. what looks like the right way is the wrong way because it gets put on the truck backwards. so it was sticking out too far. so we switched that around and everything is great now. so to say the least...i feel i am almost an expert at taking that tensioner pulley assembly off.
but in the end, everything worked out great. if any of yall have any questions, feel free to ask and i will see if i can spread the wealth of what i have learned. and thanks for all yalls help on here guys. yall are a great help.
Old 11-16-2008, 03:07 PM
jbrew's Avatar
Found some at Summit that look better, I think I'll order, not much choice on the 98, but they carry AC Clutches as well - I want to replace everything up front - To many miles - I'll be needing the truck again after the first of the year to pull 3500-4000 lbs across a few states - preventive maintenance ..
Maybe I start my own thread ? - Sorry *****, don't mean to steel yours..
Summits stuff -
http://store.summitracing.com/partde...677+4294840115
http://store.summitracing.com/partde...=1#Application
Old 11-16-2008, 03:09 PM
jbrew's Avatar
Your confusing me - Tensioner pulley is called that. Idler pulley is separate unless your talking about another vehicle , not a truck/ford..? Unless you are talking about the same thing and was just pulleys ? That would just cause more drag and kill some of your power - Wouldn't advise. - Pulleys are sized in accordance too ..
BTW- Why do you say the pulley goes on backwards to be right ? There's only one way that's right - Backwards isn't right ? I'm confused again.
Old 11-16-2008, 03:26 PM
jbrew's Avatar
Could someone tell me if #5 was an option ? I don't have one of these installed, never have.
Quick Reply: How to take off tensioner pulley?
