Cruise control does not work 00 f150
Old 12-01-2008, 07:27 PM
mike86ttype's Avatar
I did the cruise control test and I got this
Hold down off turn on ignition-got green CC light
Press on- green CC light then off then on then off
Press resume - no light
Coast - no light
Could the switch on the right side off the steering wheel be bad.
Old 12-02-2008, 07:04 AM
Norm's Avatar
Has the recall been done? The switch on the master cylinder may be bad and one step away from a fire.
Old 12-02-2008, 08:36 AM
projectSHO89's Avatar
Old 12-02-2008, 11:05 AM
BakerF150's Avatar
Does this same test apply to the newer f150s? 04-08? I tried it and it didnt work.
Old 12-02-2008, 02:37 PM
it worked last week so it is not the recall.
Old 12-02-2008, 03:36 PM
Doc Fluty's Avatar
did you add any LED tail lights?
i did last week and now my CC wont work. they say i need to get a load resistor..
Old 12-02-2008, 11:31 PM
no led tails but. The tcc unlocks when i lift off the gas above 50. it unlocks right away and u can fell it. it didn't do that before. im thinking its the break switch.
Old 12-03-2008, 08:31 AM
See the thread posted above. It TELLS you what the possible reasons for the fault might be.
Kind of removes the guesswork, eh?
Old 12-05-2008, 06:57 PM
KSFarmboy's Avatar
Did you get your load resistor problem solved? I am having the same problem now.
Old 12-05-2008, 07:19 PM
Doc Fluty's Avatar
no i didnt.. maybe this weekend ill have time to make it to pep boys or autozone to look around.
Old 12-05-2008, 10:18 PM
ok here is something weird. some times i press the cruise button and the light blinks on the dash, like it wants to turn on. And also some times i press the cruise button and the horn honks. You think its the clock spring
Quick Reply: Cruise control does not work 00 f150
