Circle Slowly To Calibrate
Old 12-17-2008, 01:11 PM
greencrew's Avatar
I'm getting this message about every other morning when I start the truck.
Why am I getting the message. I've done the circle thing twice until it said Calibration Complete. Is there a right way to circle? Do I just ignore it? Is my battery weak.
Old 12-17-2008, 01:21 PM
kingfish51's Avatar
It has to do with your compass. Check your owners manual.
Old 12-17-2008, 01:41 PM
i.ride.suzuki's Avatar
Make sure your trip button isn't stuck.
Old 12-17-2008, 01:47 PM
azmidget91's Avatar
Old 12-17-2008, 07:22 PM
stormtech's Avatar
I was just going to start a thread about this -
I'm having the same problem with my '08, but it only happens once in a while.
The first time it happened, I thought it was because I had the truck parked in the barn, but the next day it was fine.
Then I thought that is only happened when I used the remote starter, but the other day it was fine using the remote.
So, I am kind of baffled also.
Old 12-17-2008, 10:02 PM
greencrew's Avatar
Originally Posted by azmidget91
I'm on it.
Old 12-17-2008, 10:08 PM
ATOM's Avatar
weird, i know when the battery is unhooked, you will need to re-do it, something weird is going on
Old 12-17-2008, 10:56 PM
Must be global warming and the North polei s melting.
Old 12-18-2008, 12:43 AM
squirtbottle09's Avatar
Ive never had this problem with mine. Ive unhooked my battery for long periods of time and nothign ever popped up
Old 12-18-2008, 07:33 PM
greencrew's Avatar
That's what I'll do, take some time, set the zone and manually start the calibration process.
I was doing the calibration down the road under the high voltage wires which the manual says not to do.
Quick Reply: Circle Slowly To Calibrate
