5.4L 3V Owners: Check your Champion 7989 Replacment Plugs!
Old 12-29-2008, 10:42 AM
UCF-150's Avatar
Round 1 - 12/29/2008
If you've swapped out your 2 piece plugs for the champion 7989 replacement plugs - check them. After a searching relentlessly for a low grade mis fire, after having the computer changed (it died), swapping all the plugs to the champions, dealing with broken plugs, and about to swap all the coils at $45 each, I said, well, just for ****s and giggles, I'm gonna check the "NEW" plug on the cylinder that was throwing the CEL. This is what I find.
Does anyone think this might be why I'm getting a misfire?
Does Champion warranty their plugs?
Round 2 - 12/14/2009
I figured that I would resurrect this thread from the realms of the archive to show the newest plug burn.
Pulled this plug out of no 7 cyl. Now, if I was smart the first time around, I would have noted which cylinder I pulled the original plug out of swapped COP's with. I believe I pulled the first plug out of no 6, and could have swore that I swapped the COP's between 5 and 6... but I could have very well swapped it between 6 and 7 because they are easier access.
I took all the champions out and went with Motorcraft SP462 / PZT1F, and just like the first round of plug swapping, I used nickel antiseeze on the sleeves.
I'm not sure, but I think something is missing.......... (that's sarcasm)
Old 12-29-2008, 10:56 AM
Faster150's Avatar
thats damage from prolonged detonation. not really cause of warranty
Old 12-29-2008, 11:00 AM
JackandJanet's Avatar
Good grief! How many miles were on this plug? It almost looks like the nose has been destroyed by preignition, doesn't it? Except, preignition usually eats up the electrodes.
I wonder if you're running lean?
Faster150, you're too quick for me! I agree that detonation is a good guess too. UCF-150, have you pulled and looked at any of the other plugs?
- Jack
Last edited by JackandJanet; 12-29-2008 at 11:05 AM. Reason: Added note to Faster150 and UCF-150
Old 12-29-2008, 11:54 AM
jethat's Avatar
I knew there was a reason I hate champion plugs. I wouldnt put one in my lawnmower.
Old 12-29-2008, 12:47 PM
UCF-150's Avatar
no, I haven't pulled any other plugs, but i will. The plugs only have about 9k miles on them.
Old 12-29-2008, 05:08 PM
Faster150's Avatar
my dads theory was they are champions of the trash can.. thats about it
Old 12-29-2008, 07:15 PM
risupercrewman's Avatar
Dude, thats insanely crazy!.....Thanks for the post!
Old 12-29-2008, 08:30 PM
UCF-150's Avatar
so whats the cause of prolonged detination / predetination??
Old 12-29-2008, 10:08 PM
Faster150's Avatar
lean burn. to much timing. or to little
Old 12-29-2008, 11:09 PM
che22879's Avatar
My dad never let us put anything made by champion in any of our cars!!
Old 12-29-2008, 11:17 PM
04+ = excessive lean conditions anyways to squeeze MPG's out of a heavy turd truck
Old 12-30-2008, 08:34 AM
bigbronc's Avatar
Why are you running Champions? Is your truck a two-stroke? That's all a Champion is good for. Can't tell you how many running problems I've looked at and all I did was replace the Champion plugs with Motorcraft and problem solved. Ford motors don't like Bosch plugs, either by the way.
Old 12-30-2008, 02:57 PM
That doesn't look good.
Old 12-30-2008, 04:33 PM
07BlkScrew's Avatar
I resently just removed all my plugs from my 3v 5.4 it has 61,000km's all came out perfectly couln't have been happier! I cleaned all the carbon deposits off applied some dielectric grease on the COPS along with anti seize on the shaft of the plug, and just a touch on the threads and I mean just a touch!
I will most likey replace them in the spring with the Autolites from Ford, oh by the way do any parts stores sell these cheaper then the dealer?
Old 12-30-2008, 04:38 PM
Autolites are not from Ford. Motorcraft is from Ford and tho they are manufatured by the same company, they are to different specs.
Quick Reply: 5.4L 3V Owners: Check your Champion 7989 Replacment Plugs!
