pics 04-08 king ranch w/ lift
Old 01-13-2009, 01:22 PM
obrian0501's Avatar
Post pics 04-08 king ranch w/ lift
I am lifting my king ranch its an 06 white/tan in color. I wanna keep the lift looking really clean. flush wheels with the fender flares all that good stuff. i cant decide if i should get a 4" or a 6", i dont want to go any bigger or any smaller than these two sizes. not sure what brand 4" but i have had the fabtech 6" on my last truck and i wouldn't do it any other way. thanks for the help.
Old 01-13-2009, 02:44 PM
fx4 for life 79's Avatar
the fabtech is a great lift. I have seen a king ranch the same color has yours lifted around town and it is really nice. I also like the way the rancho 4" looks very clean on nicer trucks like the lariat and king ranch
Old 01-13-2009, 03:05 PM
ATOM's Avatar
no full suspension lift is gonna keep the the front tires flush with the flares like it is now. i was running the stock 20's for a while with my rancho and they stuck out almost 2 inches. most lift kit won't allow rims with such a deep backspace. if you want the tires to stay flush, then get a leveling kit and run 35's on the stockers.
Old 01-13-2009, 07:44 PM
farmboy1975's Avatar
I'm running 35's on my 6" fabtech and yes they do stick out. Just means I wash the truck a lot more.
Old 01-13-2009, 07:51 PM
06yz250f's Avatar
like its been said lifts will increase your front track width. my BDS increased about 1 7/8'". if you want stock wheels which IMO would look sick with your 20" KR wheels get the 4" rancho with the red subframe. would look very clean.
Old 01-14-2009, 12:04 PM
obrian0501's Avatar
thanks for the info. my buddies were saying the ford uses a knuckle lift system which will make the front tires stick out more but i was going to use a spacer on the rear tires to even things out. i guess ill find out once we start tearing things apart...
Old 01-14-2009, 12:39 PM
ugacoop16's Avatar
I would go with the 4 inch ranch and keep your stock 20's it will help keep the looks you are going for better than a fabtech or pro comp lift..
VTHokieF150 has this exact setup and I think its the looks ur going for...It would look real clean on your king ranch. http://www.thejonesfarm.com/2006_f150.html
Old 01-14-2009, 11:00 PM
82chester's Avatar
I know its bigger... but it is white and arizona biege......
Old 01-14-2009, 11:05 PM
Screw-Me-05's Avatar
[/QUOTE]
That is kick *** bro...
Old 01-15-2009, 07:27 PM
backwoodsboy70's Avatar
i got a 6 inch lift on my truck, and its white and arizona biege
Old 01-15-2009, 11:58 PM
ZeroDormancy's Avatar
i know u said u didnt want to go any less than 4"
but i must throw in my 2 cents. i have a leveling kit and the add a leaf in the back on 285/65/20's so all in all its got about 4" on it. looks real good and its cheap compared to a full lift...
oh and the pic in my sig is with the tires and leveling kit but without the add a leaf
Old 01-16-2009, 12:05 AM
ATOM's Avatar
you need a taller block or an aal, i wouldn't tow much with that setup
Old 01-16-2009, 10:45 AM
if you re-read my post it says i do have one. i didnt have one for about a month or 2 so i could get the funds
Old 01-16-2009, 11:45 AM
ATOM's Avatar
eitherway then why don't you post a pic of the way it sits down, personally that setup is worthless, can't tow/haul with it IMO
Old 01-16-2009, 06:53 PM
i had 3000 lbs of sand in it the other day and it did great
Quick Reply: pics 04-08 king ranch w/ lift
