Gas Gauge Problem
Old 01-13-2009, 07:31 PM
86aces's Avatar
Gas Gauge Problem
Hello everyone!
Wow what a day.. Was out doing some small deliveries in my 08 F150 (got in july 08). Just small boxes I kept in the cab.
Anyways, I always check my gas gauge, and knew I had half tank left, halfway through my trip, I hear beep beep, look at my gas gauge and it's all the way at empty and even lower. Went to the station to put gas in, and still showed empty..
Now we just got a pretty big cold front coming through Toronto, but damn! killed my whole day.. now I'm driving a ford focus! not easy being 6'7! lol.
Anyways, just wondering if anyone has had this problem? I know my situation is kind of vague, but it feels great writing it out on here! lol.
Take care!
Erik-
Old 01-13-2009, 08:09 PM
wrench007's Avatar
Hopefully you're still in warranty. Sounds like they may have to drop the fuel tank and replace the sending unit and pump assembly. Hopefully, it's something simple.. I had a 2002 F-350 PS that did the same exact thing to me, under warranty, they replaced the pump/sending unit and took care of the problem. I had a feeling it was the sending unit so I went off road, drove it over some hills, bounced around alto and when I got level again, it was fine. Next day, poof, same problem.
Old 01-14-2009, 10:07 AM
86aces's Avatar
Luckily it's still under warranty. So hopefully I go there whenever the truck is ready and not have to pay a cent lol.
Just such an inconvenience, cannot stand this Focus anymore lol..
Erik-
Old 01-14-2009, 12:00 PM
JasonFX4's Avatar
Mine has a gas guage problem too, it lies to me. Itll tell me I have gone up to 275 miles on a half a tank of gas, causing me to get excited and think its doing great on gas. Then 50 miles later its on 1/4 of a tank.
Old 02-10-2009, 02:11 PM
TK2008's Avatar
I've been having the same problem with my 08 as well. Ford replaced the sending unit last week. It was working fine until I filled up yesterday. Now it reads empty!
I called ford and they stated that this is common in the new vehicles. They said it's usually a chemical issue and recommend that I use fuel with techron or add a techron additive
Has anybody else been told this? Has it worked?
Old 02-10-2009, 05:02 PM
tmcolegr's Avatar
TSB 08-2-9
ERRATIC FUEL GAUGE OPERATION - MIL ON - DTCS P0460/P0463 OR INSTRUMENT CLUSTER MODULE DTC B1201 - VEHICLES BUILT BEFORE 12/3/2007
Publication Date: January 22, 2008
FORD: 2004-2008 F-150
LINCOLN: 2006-2008 Mark LT
ISSUE:
Some 2004-2008 F-150 and 2006-2008 Mark LT vehicles, built before 12/3/2007, may exhibit erratic fuel gauge operation or illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0460 or P0463, and/or Instrument Cluster Module DTC B1201. This may be caused by sulphur contamination in the fuel causing an open or high resistance in the fuel level sender.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Install a new fuel level sender following the service procedure instruction sheet provided in the fuel sender kit.
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132" WB )
8L3Z-9A213-F Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139" WB)
8L3Z-9A213-G Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-H Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163" WB
8L3Z-9A213-A Kit - Fuel Sender (2004 through 2008 - Gas-26 Gal Tank - 126/132" WB
8L3Z-9A213-B Kit - Fuel Sender (2004 through 2008 - Gas-30 Gal Tank - 139" WB
8L3Z-9A213-C Kit - Fuel Sender (2004 through 2008 - Gas-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-D Kit - Fuel Sender (2004 through 2008 - Gas-36 Gal Tank - 145/151/163"WB
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
080209A 2004-2008 F-150, 2006-2008 Mark LT: Install New Fuel Level Sender, Includes Time To Remove And Install Fuel Tank (Do Not Use With 9002A, 9002A4, 9002A6) 1.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9A299 42
Old 02-10-2009, 08:58 PM
Bob Chapman's Avatar
When your tank really is low add a container of Techron gas addative - should fix the problem for about $7.00. I have the same problem with my 02 Vette and the Techron solution is a common and effective fix.
Old 02-10-2009, 09:11 PM
lObOdiablO's Avatar
I notice an erratic revs gauge operation.. not a gas.. yet
Old 02-11-2009, 12:42 AM
freekyFX4's Avatar
Mine is a diesel, but I had this same problem last week. I stopped, turned the truck off, turned it back on, and the issue went away. Weird!
Old 02-26-2009, 10:10 PM
cstanek's Avatar
I just noticed something like this tonight on my 05. I ran the tank pretty low so I could start using the 91 performance program on my Edge. Even when I filled the tank all the way up with 91, the guage still showed empty and the computer says I have 10 miles until empty. I wonder what happens when that hits 0. Looks like I'll need to run this in to the dealer.
Old 02-22-2012, 09:54 AM
acidsurfr's Avatar
my '07 just started this as of this morning. Never had a problem in the past. Gas gauge showed "E" and low fuel on instrument panel. Stopped and filled up with the usual premium from Shell station by work. Got in and gas gauge barely raised above E. Contacted the dealer and they set up an appointment for next monday. Told me to cancel if it "self corrects" before then. Told them i only ever run premium from Shell or Speedway and she told me i am not suppose to run premium all of the time as the engine doesn't run hot enough to burn all of the deposits. Never heard of this, and what do engine deposits have to do with a tank or gauge issue. I am also running the Edge with canned tunes. usually run setting 3 for performance, but i have been running level 2 towing for about a month as i have been towing a drop deck trailer with a genie lift (about 7000 lb's) quite often for work lately. Any one else heard of the "premium" fuel all of the time as an issue, and the edge programming manual and everything i have read says NOT to run level 3 on anything but premium and to never run E85 with the programmer???
Old 02-22-2012, 10:57 AM
SoonerTruck's Avatar
First of all, you are replying to a thread that has been dead for a few years, so it's probably better to start a new thread on the topic instead of waking it from the dead. Second, the Ford tech was right about never running premium fuel on a stock programmed vehicle as it is a waste of money. However, you mentioned you have an Edge programmer on Level 3, which is the premium fuel level, which requires you to so you're fine. Finally, the fuel gauge is known to hang up every now and then, it usually corrects itself after a few startups.
Old 02-22-2012, 11:27 AM
If you put gas in with the engine running, that will cause gas gauge issues.
Old 02-23-2012, 09:05 AM
acidsurfr's Avatar
Sooner, thanks for the heads up...i simply did a search and found an existing one, my bad for not looking at the date. glc, the stations around here will shut your pump off if you are a) not standing outside of the vehicle b) vehicle is running hell they've even shut it off because the cashier inside saw me answer my cell phone while pumping gas. But thanks for the heads up guys. As an update, it slowly climbed up throughout the day yesterday and is now showing a full tank. Added a 20oz bottle of Techron to the tank to treat it anyhow.
Quick Reply: Gas Gauge Problem
