How do you remove a company logo off a truck?
Old 02-08-2009, 05:34 PM
johnnyd2723's Avatar
I need to remove a decal off of a company truck. It's been on for 5 years. The last one I did I used a heat gun and a plastic putty knife and it still was a major pita. Anybody know any tricks for easy removal?
Thanks in advance
Old 02-08-2009, 05:38 PM
Djacobs28056's Avatar
Let it sit in sunlight for a while to heat the metal up. Then se the heat gun. Note: depending on color of truck, it's possible that there might be a difference in color because of sunlight causing the paint to fade over time. Hope it helps.
Old 02-08-2009, 05:40 PM
dsq3973's Avatar
3M makes a woodgrain and sticker remover in a aerosol can that can be picked up at NAPA or any decent store that sells autobody supplies.
Old 02-08-2009, 05:53 PM
scotyg's Avatar
just go slow and get it nice and warm. i just used a hair dryer when i took my FX4 stickers off a couple weeks ago.
Old 02-08-2009, 07:16 PM
Thanks guys. I think I'm going to give the 3M stuff a try.
BTW 1st4x4, I've only seen the sun twice in the last 2 months
Old 02-08-2009, 07:18 PM
shorse's Avatar
wd-40 works for stickers, i dunno about vinyl's though... worth a shot
Old 02-08-2009, 07:21 PM
azmidget91's Avatar
aircraft remover will take it right off
and the paint
Old 02-08-2009, 08:58 PM
inurok's Avatar
What method would be best for me to remove the lame 4x4 stickers on the back sides of my lariat?
Old 02-08-2009, 09:02 PM
and the paint
Uhh, sounds good. How much is a qt of oem AZ Beige paint?
Old 02-08-2009, 09:06 PM
Those will peel right off with a heat gun or hair dryer. Much easier than the commercial vinyl decals. After you take the lame 4x decals off the F1 try it on the lame decal on the back of the 7
Old 02-08-2009, 09:21 PM
wrobo23's Avatar
Let it sit in the sun and use a heatgun and your fingernail.
If that doesn't work, see if anyone has one of those "erasers" for decals (like an auto place) - they work wonders (used with a compressor)
If that doesn't work, spray a little easy off oven cleaner on and in 10 secs it should melt off. (If you do this, make sure to clean the area well afterwards - I usually clay bar then wax as that crap is harsh)
Just a few thoughts
Old 02-08-2009, 09:38 PM
hwm3's Avatar
My suggestion is to try a hair dryer, not a heat gun. If not used very carefully a heat gun can burn the paint. A hair dryer and some plastic razor blades should allow you to remove the vinyl.
Whatever you do, don't use ANY oven cleaner on your paint.
Old 02-08-2009, 09:59 PM
inurok's Avatar
Jealous much...
Old 02-08-2009, 10:04 PM
Jealous much...
Yeah, a little but still for the love of god.....
Old 02-08-2009, 10:32 PM
inurok's Avatar
Lol seriously that sticker on the back of my car is lame the dealer put it on the car to tag it as theirs.
Quick Reply: How do you remove a company logo off a truck?
