Warning Buzzer 5 times 5 times HELP!!!
Old 03-04-2009, 10:08 AM
dgroff's Avatar
I have a 2004 F150 screw. Just recently my truck's wanring buzzer has been going off about 1 min after I start the truck. ther are no wanring lights in the dash cluster, just a buzzer that buzzes 5 times and repeats 5 times.
Can anyone help?
Old 03-04-2009, 10:18 AM
SSCULLY's Avatar
Search this forum for the term beep there are 72 threads.
If you read through them, this is a case of Your airbag warning light in the dash is burned out AND there is a fault in the airbag system.
https://www.f150online.com/forums/el...tone-code.html
Quick check, turn your turn your ign to the run ( do not start ) position, and the bulbs should illuminate. You should not see the airbag light on the cluster.
Old 03-04-2009, 10:33 AM
dgroff's Avatar
The air bag light in cluster comes on than goes out same as the passenger on/off air bag light. but I did have a code of the impact sencer in front of the rad. I checked it and found a crack on it and just waiting for dealer to get me one. Do you think this might be all in one same problem?
Quick Reply: Warning Buzzer 5 times 5 times HELP!!!
