Spark Plug change on a 2001 Ford f150 Supercrew 5.4 Triton
Plug Link - http://mattstruck.com/sparkplugs/sparkplugs.html
Mikes 2 valve info (towards the bottom) helps as well -
https://www.f150online.com/forums/1870237-post14.html
Coil On Plug, no plug wires.
take 4 small bolts off of fuel rails to lift up a bit as the rails are right above a few of the coils.
small 7mm bolts on each coil before able to pull coil pack up and off, don't quote me on 7mm though
Use about a 6" extension on top of a spark plug specific socket so it will lift the plug out once unthreaded.
may be a good idea to use a shop vac to suck out the dirt in all the injector and spark plug holes before reassembly, these motors have a bad tendency to collect dirt and grime in many areas. good luck and feel free to pm me for any quetions on the way. also a little dab of engine oil on the injector O-rings helps out alot when going back together.
and make sure all the orings stayed on the injector, if not dig the oring either out of the intake hole or fuel rail and put back on the injector or you'll play hell.
