Old 04-13-2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Please Help, F150 stuck in 4 Wheel Drive
http://www.f150online.com/forums/oth...eel-drive.html
ISSUE
1997 4x4 xlt 5.4 stuck in 4 wheel drive mode after not being drive for 3 days. There are many suggestions for the problem and to help overcome this issue, including:
• Disconnecting the battery, and rec-connecting again
• Possible vacuum leak
• Jacking up the wheels may allow you to shift back.
Read below for the full discussion…
Print Wikipost
please help, f150 stuck in 4 wheel drive
Old 03-08-2009, 01:16 PM
gofordguy's Avatar
Hello i have got a 1997 4x4 xlt 5.4 and i parked it for 3 days and then i started it up and drove away but it was stuck in 4 wheel drive, i was wondering if i blew a fuse but i checked all of them and they were good please help
Old 03-08-2009, 05:50 PM
chris_w_2008's Avatar
manual 4wd shift or do you have the switch?
Old 03-09-2009, 10:06 PM
gofordguy's Avatar
switch in cab
Old 03-12-2009, 07:34 AM
SteveStLoo's Avatar
Were you in 4x4 when you parked it?
I believe if theres a vacuum leak in your 4x4 engage/disengage system, the vehicle will revert into 4x4 mode, to prevent being stuck.. but one of the other members can verify this.
Old 03-12-2009, 11:10 AM
JMC's Avatar
JMC
JMC is offline
A vacuum leak will leave the axle in the same position it was in before the leak. Are you sure that it is actually in 4x4? On dry pavement it will bind when you try to turn. Is the 4x4 light on? Low?
Old 03-12-2009, 05:02 PM
gofordguy's Avatar
Thumbs up yes
yes i'm sure it is, like you said it does bind up when i try to turn on dry pavement and yes the regular 4x4 light is on the dashbord
thanks everyone for your help so far and please keep it coming
Old 03-24-2009, 04:52 PM
gofordguy's Avatar
update
hey everyone i am here to update see my truck was stuck in 4 wheel drive high then we got it out of high into 4 wheel drive low then we got out of 4x4 now it is just stuck in low please help
Old 03-24-2009, 06:54 PM
do you hear a click in the dash at all? if not might be electronic. or could be you hubs somehow
Old 03-24-2009, 08:58 PM
gofordguy's Avatar
i only herd a click when it went from 4x4 hi to 4x4 low and just in low i also checked all the fuses and they were all good
Old 03-24-2009, 11:01 PM
JMC's Avatar
JMC
JMC is offline
How did you manage that? Repeatedly turning the shift switch?
Regards
Jean Marc Chartier
Old 03-25-2009, 06:53 PM
gofordguy's Avatar
yes to get it in to 4x4 low i shifted tnto neutral and then i tryed again and it did not work
Old 03-26-2009, 12:32 AM
JMC's Avatar
JMC
JMC is offline
As per the owner Guide:
1. Bring the vehicle to a stop.
2. Depress the brake.
3. Place the gearshift in N (Neutral) (automatic transmission) or depress
the clutch (manual transmission).
4. Move the 4WD control to the 4H
or 4L position.
Regards
Jean Marc Chartier
Old 04-01-2009, 10:13 AM
1. disconnect the battery
2. Remove motor from t-case and manually switch it back to 2WD worked for my '97 and never did the same BS again
Removing the motor is very easy then just vise grip the shaft and turn it will show you what direction
Old 12-27-2009, 10:29 PM
TN F150 fan's Avatar
Thank you! Thank you! I did this today and it worked just like you said. I left my 1997 F150 in 4x4 High for 3 days because my driveway was snow covered and it would not go back into 2 wheel drive once the snow was gone. After I did step 1 and 2, reinstalled the transfer case motor and hooked the battery back up, it works just like it is supposed to.
Old 12-28-2009, 01:24 AM
tx_proud1's Avatar
my 2002 f- 150 4x4 won't do anything when i switch from 2h to 4h or 4l....no clicking or light saying it's in 4 wheel drive...any suggestions??
Quick Reply: please help, f150 stuck in 4 wheel drive
