Low beams not working, high beams work
Old 04-07-2009, 10:56 PM
valentmc's Avatar
My low beams both went out on my 1997 f 150. High beams work when i pull the turn signal lever in. Checked the fuses and replaced the headlight bulbs and no go. Any thoughts ? Multifunction switch ? Thanks for any and all help.
Old 04-08-2009, 12:06 AM
SSCULLY's Avatar
Did you check for power at the bulb connector ?
Next would be to check for power on both sides of both fuses
Old 04-08-2009, 09:03 AM
valentmc's Avatar
No I have not, but I will. I assume you're referring to the socket, aka bulb connector ? If so, I assume it would be ok if the brights work.
Old 04-08-2009, 09:33 AM
SSCULLY's Avatar
Yes the socket / connector are one in the same ( too used to calling things connectors ).
If the brights work, you will have voltage on only 1 of the 2 pins ( the 3rd is ground, which is black ).
The fuses, there are 2 fuses for the low beams ( cab fuse panel fuses 26 & 28 ) and 1 fuse for the high beams ( cab fuse 16 ).
Best to start with turning the headlamps on,and checking on the pin on the back of the fuse ( both sides ) for the low beams. Easier then yanking your headlamp housings out. Make sure you have a good ground when testing, as not to get a false reading.
If these are dead on both sides with the main headlamp switch turned to the head position, and the MFS in the low position, then there is a problem with the MFS, and time to remove and test it.
Old 04-08-2009, 09:37 AM
SSCULLY's Avatar
Sorry, threads on the MFS & cleaning it
https://www.f150online.com/forums/el...on-switch.html
https://www.f150online.com/forums/el...r-gremlin.html
The other you would see when taking it out, is a loose connector in the steering wheel column.
Which makes me think of another item, try moving the tilt on your steering wheel all the way down ( try low beams ) and all the way up ( try low beams again ).
This might diagnose the difference between the MFS and the connector.
Old 04-08-2009, 12:31 PM
valentmc's Avatar
Headlights not working
Thanks Sscully. I will use this info tonight to investigate my problem. Will keep you informed
Old 04-08-2009, 05:19 PM
98Expedition10's Avatar
Don't forget that you do have two fuses, and two relays that control the HL circuit. The fuses and relays are in your UH-EC Fuse/Relay Box. The MF switch controls the relay coils first.
Old 04-08-2009, 05:34 PM
SSCULLY's Avatar
Relays are only with Autolamps
1997 EVTM cell 85-1
Old 04-08-2009, 10:36 PM
DCLoppy's Avatar
i have exactly the same problem, 1997 XLT - only high beams. I checked for power at both fuses and I have 12 V at each one - on opposite sides of the fuse - i.e. there is 12 V on the right hand socket on one, 12 V on the left hand on the other. Is that weird - or is that how the fuse box is wired in the back? Anyway, having power there would seem to rule out the switches - so what is left ( no autolamp in this truck)
Old 04-09-2009, 09:00 AM
SSCULLY's Avatar
You pulled the fuse to check, or checked the pins on the back of the fuse ?
This is opposite sides of fuse 26 and 28 ?
You high beams, are they with the FTP feature ( flash to pass / pull back on the MFS ) or both FTP and normal operating ( push forward ) ?
If you have power to one side of fuses 26 & 28 with the main headlamp switch turned on, the MFS should be OK, as Fuses 26 & 28 are fed by the MFS.
If you test the back of the fuse for 26 & 28, and have power on both sides with the headlamp switch turned to the head position, time to check for power at the headlamp bulb connector.
PS : See you do not have Autolamps, do you have DRLs ?
Old 04-10-2009, 04:37 PM
valentmc's Avatar
I dont have power at the fusebox with the headlight switch on. MFS then ?. By the way, no autolamp for me.
Old 04-10-2009, 04:38 PM
valentmc's Avatar
Also switched out the relays and still no go
Old 04-10-2009, 04:52 PM
SSCULLY's Avatar
Pull the MFS and test it with the chart above, but if fuse slots #26 & #28 have no power with the main headlamp switch on, I would think MFS or the connector in the steering wheel column.
What relays did you swap, there are none without Autolamps on a 1997 ( see diagram above from the 1997 EVTM cell 85-1 headlamps, no autolamp )
Old 04-11-2009, 08:04 PM
DCLoppy's Avatar
Here is what I have so far:
Power on one side of both fuse sockets, fuses are good, no power at the light sockets. Is there a connector behind the fuse block that might have worked loose ( over a year ago I replaced the heater core, so all of the dash has been pulled out and stuck back in - in the process something might have been affected - again over a year ago).
Thanks for the help so far.
Old 04-12-2009, 12:09 AM
valentmc's Avatar
ok. changed the MFS and I have headlights. thanks for the help. by the way, changing out the switch was scary easy. thanks again
Quick Reply: Low beams not working, high beams work
