Auto Door Unlock?
Auto Door Unlock?
Does anyone know if our trucks have a feature to auto unlock the doors when you get out of the truck?
I had this feature on my 04 Ram. I would turn the key off, open the drivers door and all the other doors would unlock. This was helpful to me because I have 2 kids and need to open the doors to get them out and it saves me a step of having to unlock them with the button.
I am so used to this feature that I find myself forgetting to unlock the doors and getting upset because they are locked.
I looked in the manual but didnt see anything about it in there.
I am 90% sure that the factory lock system doesn't do this and won't do this with any of the settings changed within the programming system.
Every Code Alarm that I have ever had does this though. I currently have the SRT-9000 model and as soon as I start the truck it locks all the doors. However, if it detects that one of the doors is open, it will immediately unlock the driver front door to keep you from being locked out. It will also do the opposite as well. When I turn the truck off, all the doors are immediately unlocked.
I don't ever use the door lock/unlock button anymore. The alarm takes care of it all for me. Plus the install wasn't too bad. Only took me a couple hours and is a fantastic alarm.
I know the 2004 does not have this feature, but I thought 2006 and up did. Anyway here is some info, maybe give it a shot, you never know.
Enabling/Disabling Autolocking, AutoUnlocking, Trim Switch Inhibit, and Perimeter Lighting:
1. All doors must be closed and remain closed throughout the configuration process
2. Turn Ignition to RUN
3. Press the Trim Panel Unlock Switch three times Turn Ignition to OFF
4. Press the Trim Panel Unlock Switch three times
5. Turn Ignition to RUN
This sequence must be accomplished within 30 seconds. Completing the sequence within 30 seconds enters program mode and is confirmed by a horn chirp. Once programming mode is entered, the feature listed below can be enabled or disabled. Each interior switch activation must occur within 5 seconds of each other in order to successfully toggle the function.
Feature................First Press.......Second Press
AutoLock.................Unlock..............Lock
AutoUnlock...............Lock...............Unlock
Lock Inhibit...............Lock...............Lock
Perimeter Lighting......Unlock............Unlock
Pressing UNLOCK/LOCK toggles the state of Autolock (if it is off this turns it on, if it is on this turns it off)
Pressing LOCK/UNLOCK toggles the state of AutoUnlock* (if it is off this turns it on, if it is on this turns it off)
(* new for '06. Unlocks all doors once key out of ignition and one of the front doors are opened)
Pressing LOCK/LOCK toggles the state of Trim Switch Inhibit (if it is off this turns it on, if it is on this turns it off)
Pressing UNLOCK/UNLOCK toggles the state of Perimeter lighting (if it is off this turns it on, if it is on this turns it off)
MeanGene
Tried it and it does not look like it works. The truck goes into programming mode but nothing happens when I follow those instructions.
Code58
My kids are still in car seats so I dont have to worry about them running off. Its just easier for me to get out and open their door without having to push any buttons. I guess I am just used to it. I had a 3 series BMW and a Ram that both did it and my wifes lexus does it as well.
Code58
MeanGene
Code58
Code58
My wife's Lexus takes some getting used to. The doors unlock when you put it in park, and lock when you put it in drive. If you stop to pick someone up you just have to remember shift it into park. I hated that at first, but it's growing in me. You find a spot, put it in park, the doors open and everyone gets out.
There is good reason for not needing the safety. Not all of us park our truck on the street, and we don't all have little kids. My youngest just graduated from U of Minnesota last Saturday.
Did you hear about the lady who called 911 because her car doors were locked, and she could not get out. True story. The 911 operator walked her through pulling the locking mechanism so she could get out.
