3" Body Lift vs 6" lift
Everything I've read says that it is a pain to install a body lift on the '04-'08 f150s. If you have a tow package it involves cutting the hitch and then re-welding after the lift is installed and I also read that the fan shroud is a pain to deal with on a body lift for these models. If you have the funds, I would recommend going with a 6" with coil overs. Truck looks good!
2.5'' leveling kit + 3'' body lift + 1 or 1.5'' add a leaf. (Will be taking off the leveling kit and putting a Fabtech 6'' in a couple of weeks).
Why am i going with a suspension lift. Simple, more clearance under the frame (protect the transmission, transfer case, front diff...) and i'll have stock angle up front (cv, direction, ball joint...) and when my tire wear out, i'll put 37''.
[QUOTE=fx4 for life 79;3748496]id go with the suspension unless you are installing the body lift yourself cause for the price of a bl installed you could get a full suspension lift just about
here is when i was lifted 6"
Thanks for the pic, I have a better ideal of what my truck will look like with a 6" lift, I am kinda stuck between the lifts 1. price 2. dont know how the 305/65/18 will look under 6".
[QUOTE=°°Pat°°;3748586]2.5'' leveling kit + 3'' body lift + 1 or 1.5'' add a leaf. (Will be taking of the leveling kit and putting a Fabtech 6'' in a couple of weeks).
Your truck looks great, by lookin at it i can not tell it is a body lift, i sent this pic to my wife to show her how my truck would sit, got quoted around 1050 for the 3" and the gap guards. Thanks again man
[QUOTE=fx4 for life 79;3748645]i used to have 305/70/17 and it looked ok
Thanks, for all the help cant wait to get something done to my truck, any time i am on the internet i am looking at pics of lifted f150s trying to make up my mind, Sucks being in Iraq and trying to get this done, I just want my truck to be lifted by time i get home either a 3" or 6". Thanks!
So the lift will be on in a couple of week, just need to order it. The tires and gear probably next year.
I'll probably keep half of my leveling kit, so it will be 6'' + 3'' + 1'' for a total of 10'' and if i want more lift down the road, i'll be able to put the other half in for an other 1.5''
You can look at my album for more picture.
https://www.f150online.com/forums/me...eside-fx4.html
no , the ride quality stays the same , the only things that will / might effect the ride, is if you put a leveling kit on top , and a more agressive/larger tire.
Body lift is nice for the price but I would just save up for a suspension lift
Heres my setup
3" Bds body lift
2.5 Leveling kit
20x10 mazzi hulks
35/12.5R20 Toyo mt's
Here are some of my most recent pics
Heres my setup
3" Bds body lift
2.5 Leveling kit
20x10 mazzi hulks
