Best Amp for JL 13TW5
Old 06-08-2009, 11:53 AM
bambam45249's Avatar
Question Best Amp for JL 13TW5
I am installing 1 JL 13TW5 sub in my 09 Screw. It is a 600W 3 Ohm speaker. I was thinking of the JL 500/1v2 but at 3ohms, I'll be lucky to get 375Watts out of it. I was thinking of a 750W amp and I would be a little over 550 at peak wattage. Any suggestions or input?
Old 06-08-2009, 12:42 PM
Devildog101's Avatar
I believe that the JL Slash series amps are the same wattage from 1-4ohms. May want to check out the website for accuracy...
Devildog101
Old 06-08-2009, 02:54 PM
RegularJoe's Avatar
Yes they self adjust. That amp does 500rms no matter what ohms (from 1.5-4 ohms).
http://mobile.jlaudio.com/products_amps.php?amp_id=439
Old 06-08-2009, 06:21 PM
JJDH's Avatar
that amp has ***** u would be fine 500/1v2... now if u feel real good do the 750/1 hd jl.. either way u wont go wrong,
Old 06-09-2009, 12:07 AM
kuruption's Avatar
Yes, the JL Audio amps (and Alpine PDX amps) use regulated power supplies that produce the same output under various loads. Traditional amps use unregulated power supplies.
Old 06-22-2009, 12:09 AM
emarciniak's Avatar
Just installed my TW5 today, powered by an Alpine PDX 1.600. The thing pounds!
Old 06-22-2009, 01:02 AM
sbchris's Avatar
Use the 750/1 HD. I've got the one and it is an awesome amp. The thing is ridiculously small too.
Old 06-22-2009, 01:03 AM
mSaLL150's Avatar
How much airspace is your sealed box? That will be the determining factor to how much power you can send to that speaker. A super small box and you can use gobs of power....a really big box and it will bottom out with much less power....
Old 06-22-2009, 01:54 PM
KevinBo6GT's Avatar
Any pics of the set up with the TW5? im really interested in how this setup looks/ performs
Old 06-23-2009, 07:17 PM
sbchris's Avatar
Using a seat lift?
Old 06-23-2009, 08:43 PM
WhiteRoush3's Avatar
Ive got the 13tw5 and run a JL 500/1 amp with it. love the sound...pics in my album.
Old 07-18-2009, 12:40 PM
zbornac's Avatar
I've got 2 13TW5s installed with independent 500/1v2s. Works great for me. I think the HD750 would be a bit much.
Quick Reply: Best Amp for JL 13TW5
