Fuse box location 2006 f150
Old 07-03-2009, 11:14 PM
cjkoz1975's Avatar
Can someone please tell me where my fuse box is located. This is the first vehicle I have owned that I could not find it. I put some led tail light bulbs in, and all of a sudden my left turn signal doesn't work. The light still lights up when all the lights are on, just no flashing when the turn signal is on. Any ideas?
Old 07-03-2009, 11:50 PM
SSCULLY's Avatar
Don't feel bad, took me a few to find it, the description in the manual was not the best ( to the Right of the instrument panel ?? )
It is in the passenger side kick panel. You will see the passenger side kick is a lot thicker than the driver's side.
Finger notch to the front of the truck, pull this in a swinging motion to the rear of the truck ( like opening a door ).
Behind the access cover is the cover to the fuse panel, and the fuel inertia switch is also back there.
Old 07-03-2009, 11:58 PM
also switching to LEDs you often need to replace the flasher module with a LED compatiable one
Old 07-04-2009, 12:22 AM
SSCULLY's Avatar
Also, upgrading the flasher to one made for LED tail lights, the Cruise Control might not work anymore.
Quick Reply: Fuse box location 2006 f150
