Replacing broken exhaust studs, Dorman or Ford
Old 07-25-2009, 05:51 PM
mikerosi's Avatar
Guys, what studs would you use the Dorman product or the Ford stainless ones?? Also do I need to remove the Y pipe clamp to lower the down pipe. I searched but did not see any reviews on which studs to get. Thanks Mike
Old 07-25-2009, 05:55 PM
keith97xlt's Avatar
might as well go with the ford stainless.. i would just go ahead and replace the manifold to y pipe studs also...those are known for rusting down to nothing also. put aside a whole day for this ..some studs might break off.
Old 07-25-2009, 06:13 PM
mikerosi's Avatar
Yeah, that sounds like good advice Keith. How about the down pipe, can I lower it enough or do I have to take the clamp at the y-pipe off?
Old 07-25-2009, 07:13 PM
keith97xlt's Avatar
shouldnt have to... take out those 2 flange studs and the manifold will come right out. no need to mess with the y pipe. your talking about replacing the mainfold studs right???
Old 07-25-2009, 07:16 PM
mikerosi's Avatar
yes I am replacing the manifolds, thanks Keith for the info, Mike
Old 07-26-2009, 08:58 AM
keith97xlt's Avatar
you might have to take out the starter to get to the bottom ones on that side... they are a pain.
Old 07-30-2009, 03:31 AM
IDAHO-F150x2's Avatar
Pull the tire and inner plastic fender and you should easy access to the studs. I spent more time soaking the studs than actually removing and replacing them.
Quick Reply: Replacing broken exhaust studs, Dorman or Ford
