Expedition / Navigator
Pics of lifted Expedition EL?
Old 08-01-2009, 09:07 PM
Gansettsurf's Avatar
Hi-
New to the forum. I've got an 09' F150 and an eb explorer (wifes). I'm going to be purchasing an expedition el and would like to add some larger more agreesive tires, and possibly a lift. Nothing to crazy since it's going to be a daily driver.
I would love to see some EL's with a lift and or larger tires. I've searched through the forum without much luck. Any pics and advice would be appreciated.
Thanks,
Dave
Old 08-02-2009, 12:33 PM
expedition4x4's Avatar
i THINK there are leveling kits out but i dont know anyone who has bought, i havent seen any of the newer expys lifted only lowered
Old 08-02-2009, 02:03 PM
Yeah, I've searched the www pretty extensively.... I'm trying to see what I want to do in reference to tire size and amount of lift.
Old 08-02-2009, 05:22 PM
i don't know much about lifting but i think with the leveling kit you can fit 33s
Old 08-02-2009, 07:03 PM
That may do it, I'm not looking to go crazy, I just hate anything stock! Anyone with pics please post! I'm still surfing the web looking for info. Not much around.....
Thanks for the response.
Old 08-06-2009, 01:14 PM
have you found anything? i'm curious to see some lifted expys
Old 08-14-2009, 11:51 AM
Nope!
I'm having trouble finding a good shop locally to discuss the whole project as well. Oh well....
Old 08-14-2009, 12:03 PM
time to go low?
Old 08-15-2009, 12:09 AM
Jpaye's Avatar
http://www.rizeind.com/03products/02...en_ford01.html
Rize makes a kit, looks like more than you want but the pictures of the expedition look Bad A$$
Old 08-15-2009, 01:12 AM
NoLongerJeepin's Avatar
^^^ badass.
Old 08-15-2009, 12:56 PM
that looks good!!
Old 08-15-2009, 05:38 PM
MonteCarlo31's Avatar
Rancho has the quick lift kit out there. It's a top quality piece, runs under 1 grand for all 4 corners if you shop around, probably 1100 with the hand-held ride control. The kit will allow the expedition to clear 35s on OE rims.
Old 08-16-2009, 06:19 AM
Tylus's Avatar
that rize lift won't work on the 2007+ Expy. shame, because that is a sexy beast.
Old 08-24-2009, 10:25 AM
dkm2's Avatar
If you are getting a 2wd, you are going to find it very hard to find a lift, if you can at all. I have the 2" Spacer Lift on all four wheels and fit 33's nicely. Might be able to go 34 ish but think I would have problems with 35's. I found recently a 3" spacer style lift which claims 35's would fit. Check out Ready Lift Kits on jackit.com. It says for use on 03-09 4wd/2wd Expeditions.
Old 08-25-2009, 01:46 AM
Tylus's Avatar
the 07+ Expy can't swap lift kits with a 03-06 Expy.
they share the same front coil-overs...but that is about it. Ford tweaked the rear IRS a bit and none of the Lift Kit companies have done the necessary changes yet to make a 100% bolt-on kit.
Most likely you could buy a 03-06 Lift Kit, but it's going to require custom fabbing in the IRS
Quick Reply: Pics of lifted Expedition EL?
