Replace 04-08 fan blower motor resistor EMTC HVAC
Old 08-06-2009, 10:13 PM
mjb1032's Avatar
This is a VERY easy repair....
If your fan isn't working on all speeds, the fan motor resistor is most likely what's faulty.
There are two types, one if you have automatic temperature control, and one if you have manual.
This is the manual one, Motorcraft part #3F2Z18591AA.
One Ford dealer quoted $22.17, another said $36.00
1) Open the glove box beyond it's stop by pressing the right side in, till the rubber stopper clears the side.
2) This is the part to replace.
3) The screws are 8mm.
4) Slide the part out....it's credit card size.
5) Press the center tab to remove the connector from the part.
Reverse these steps with the new part, and you're good to go!
Old 08-07-2009, 11:45 AM
Altatruck's Avatar
haha TP in the glove box is an essential at all times, especially for work and camping.
Old 08-07-2009, 12:10 PM
mjb1032's Avatar
I knew someone would get a laugh at that!
Beats using leaves...
Old 08-07-2009, 02:14 PM
subcooled's Avatar
They're nice and easy to replace....once you know where they are that is.
Old 08-07-2009, 05:40 PM
Jza's Avatar
Jza
Jza is offline
what are the symptoms of this problem?
Old 08-07-2009, 08:53 PM
craneman's Avatar
TP never leave home without it.
Old 08-08-2009, 10:46 AM
Circuit's Avatar
If your in cab blower fan does not spin on all speeds. Mine was 1 and 2 did not work. Mine cost $22 CDN from the dealer.
Old 08-08-2009, 02:24 PM
Jza's Avatar
Jza
Jza is offline
oh ****, I think I may have the same problem.
I usually keep it at max speed or windows down so I didn't even notice hahahahaha
Old 08-08-2009, 11:24 PM
Circuit's Avatar
Don't feel bad. I have had my truck for over 2 years and always wondered why speed 1 and 2 were so quiet... It was because they didn't work.
Old 08-09-2009, 03:06 AM
Fabian06SC's Avatar
i remember these problems from the old resistor coil fan speed days on my s10. I cant believe 20yrs later and manufactures still havent done enough to make a decent fan speed circuit that doesnt eventually burn up.
Good post, now i know where it is when it eventually goes out.
Just to add to the OP. the glove box comes out entirely with the removal of two 7mm screws. I have found on plastic "hinged" parts that its easier to remove them than to bend them 90* in reverse.
Old 08-09-2009, 12:05 PM
ljmwi's Avatar
Is this easy fix the same for an '03 supercrew? the 3rd fan speed doesn't work on mine.
Old 08-17-2009, 07:11 PM
lkalis's Avatar
Thanks so much, worked great. I had the same issue over the weekend. I bought the part for $37 at our local ford dealer, but could have purchased it for $19 at http://www.forddirectonline.com/ I have not used that site before, and did not like the fact that they won't tell you how much shipping is. They'll just add shipping at the time the order sent. I didn't want to risk a ridiculous shipping and handling fee.
I have to work on the speed control going out next (cruise control). Does anyone know what the orange wire is in the picture above? Perhaps an antennae? Just wondering as I am having zero luck finding a post as helpful as this one was for fixing the speed control.
Thanks again for the great post.
lk
Old 08-17-2009, 07:51 PM
Circuit's Avatar
It is the antenna lead.
Old 08-17-2009, 08:21 PM
subcooled's Avatar
This website is good for wiring http://www.the12volt.com/
Old 08-17-2009, 08:28 PM
aPINCHbetter90's Avatar
did you order the new resistor from the dealer? cause mine has this same problem and im so sick of turning it from setting three to off a million times while im driving cause its either to hot or to cold without settings 1 or 2.
Quick Reply: Replace 04-08 fan blower motor resistor EMTC HVAC
