How To: IWE Solenoid Replacement with Pictures.
Old 07-30-2009, 03:47 PM
mrolgren's Avatar
Heres the facts...
This has happened 3 times for me in the past week.
1) under Heavy or Light acceleration or constant speed
2) hear a whirring noise from the front of the truck
3) slow down to nearly a stop < 10 MPH
4) Hear 2 clunks, 1 on passenger side then immediately following 1 on drivers side
5) problem goes away for a day or two and then happens again
The best way i can describe it is that it sounds like i am trying to engage my 4wd and the gears are just spinning until i slow down enough for the teeth to engage.
I was refereed to this post for additional information on the topic
https://www.f150online.com/forums/3572563-post2.html
Old 08-10-2009, 09:43 AM
mrolgren's Avatar
UPDATE - IWE Solenoid Replacement with Pictures.
All,
Here are my findings on my problem above.
1) TN-150 has a post on IWE's here IWE Removal
2) xjcamaro89 has a post on the whole IWE System here
IWE System Operation
3) and here is my contribution, my pics of the replacement
IWE Located behind the battery on the firewall.
Removal of IWE Solenoid from bracket if your new one didn't come with a new bracket and you need to reuse the old one. Just clips into the bracket, clip shown here.
difference between old and new (water shielding on the new one)
Prior to hooking up the Plug and Vac Lines
All hooked up
Part Number / Box
If you have any questions on replacement of the solenoid, the pictures are in my albums in my profile, or feel free to PM Me.
Hope this helps everybody out!!!
Old 04-29-2010, 09:03 PM
tomatillo's Avatar
IWE: Bush league
Spent $390 at the dealer today. I wanted to spare my trans/transfer case.
It's a 2005 with 49k mi. Highway. Babied truck.
All the sudden I hear this CLUNK then a bearing noise. Or so I thought.
We paid to have $30 can of lube .... applied to the slip yoke. Not it.
Then, finally, I discovered that when I put it into 4wd, the noise stopped immediately.
WHY, isn't it designed to require vacuum to go TO 4WD, versus staying in 2wd. What a blunder. You could save some hubs, damn it, and a lot of quick actions to pull off the road because of the grinding and banging.
THIS IS A SAFETY PROBLEM, FOLKS.
I love Ford. That's all I buy, but it's time to stand up and do a recall on this.
It won't happen until a class action.
State your interest. If it is repaired under recall, your money spent to fix their blunder will be refunded.
It's a Ford truck. It shouldn't rely on vacuum, or suck so much, to keep it in gear.
Old 06-27-2010, 09:39 AM
Iowa4x4's Avatar
Well, I started to experience this intermittent problem and, after checking the forum, just spent $37.00 to fix the problem. This site is great! Two issues with my truck in a week, check the forum and save hundreds by repairing myself. Yowza!!!
Old 06-30-2010, 10:45 AM
stuckiniraq's Avatar
Just ordered the new part myself, will switch it out with the old one tonight and hopefully it solves the problem. Thanks for the pics
Old 06-30-2010, 01:03 PM
mrolgren's Avatar
glad it helped you guys out!
This forum has helped me many times, I'm happy I've been able to give back!
Old 07-04-2010, 12:14 AM
TheoK's Avatar
Thanks Mrolgren
Thanks for your post. It was very informative and very helpful. Fixed my problem for $28 and no trip to the dealer service center. Love the pictures very helpful.
Old 07-06-2010, 01:30 PM
mrolgren's Avatar
3 hits in the past couple of weeks.
Nice to see everybody is winning on their own repairs!
Old 07-07-2010, 12:28 PM
EXTASIS's Avatar
GREETING TRUCK MANIAC .....
FREIND MROLGREN ...
THANKS FOR THE PICTURES
I DO NOT HAVE THIS PROBLEM
BUT TO PREVENT REMOVAL OF PART AND WATER PROTECTIVE manufactures
AS THEY SAY BETTER TO PREVENT LAMENT JEJEJE
THANK YOU
Old 04-18-2011, 07:35 PM
BoatHauler's Avatar
I had to register and say THANK YOU! This forum saved me an expensive trip to the shop. I picked up the part for $28 and installed it myself. I'll be reading a lot more in the future. Thanks again!
Old 04-24-2011, 09:49 PM
scabs3's Avatar
Yeah F150 Online
Thank,s for the helpful pics saved me an expensive trip to the shop.
Old 04-24-2011, 09:51 PM
scabs3's Avatar
Hi noticed you just replaced IWE soleniod, where did you pick up part Dealer or are they available aftermarket.
Old 04-25-2011, 09:37 AM
BoatHauler's Avatar
Where I go the part
I believe you have to get the part from a Ford dealership because it is a motorcraft part. I picked it up at my dealership here for $28 with tax.
Old 04-25-2011, 12:45 PM
scabs3's Avatar
Thanks for info picked 1 up this morning from Ford $37 Can. Had it installed in 20 min. . Its amazing how much money you can save with a little bit of reading here on F150 online.
Old 08-11-2011, 07:50 PM
sparkygrl66's Avatar
I just had to say THANK YOU so much for your post and pictures of the IWE solenoid replacement process. I have a 2004 F-150, and am going through this same problem. Being a woman, there's always the stereotype that we don't know what we're talking about when it comes to auto repair. I went to the dealership today to get the NEW design of the IWE solenoid. Armed with the part numbers, both old design, and new, obtained from here. The service tech told me they only carry the OLD design, and that they are exactly the same part. I argued the difference with him, and asked to see the part so I could point out the difference based on what I had learned from your pics, and he refused. I told him to order me the NEW solenoid and gave him the part number. I explained that I was not stupid and that it was obvious that they had some inventory of the old parts they'd like to get rid of, but that I wasn't going to be one of the takers. I paid for my NEW part, $31.25 with tax. LOL, my husband went along for moral support I guess, and told me later how proud he was of how I handled thhe situation. THANKS AGAIN!!!
Quick Reply: How To: IWE Solenoid Replacement with Pictures.
