what kind of transfer case and transmission do i have
Old 08-13-2009, 03:47 PM
homasi9251's Avatar
its a 97 ford f150 4x4, she took a **** and she needs to be fixed any help at all will be highly appreciated... thanks!!!!
Old 08-14-2009, 01:03 PM
Starting a new thread isn't going to get you any better advice.
Old 08-14-2009, 01:07 PM
FX41's Avatar
4R70w Tranny
Old 08-14-2009, 05:04 PM
chiefFX4's Avatar
Originally Posted by FX41
4R70w Tranny
and you know it's that one how?
Old 08-14-2009, 10:18 PM
Because from around the early 90's to present, that is what Ford put in the Crown Vics, Mustangs, Mark VIIIs, F150s. Some of the trucks early on had a something 40 transmission and the Lightning had a heavy duty something 100.
If you want to know for sure, look at the trans code on your door jam sticker and google Ford transmission codes to find out what you have.
This web address tells you a few things about your truck if you punch in your vin#.
https://www.fleet.ford.com/maintenan...ls/default.asp
I wonder what a transfer case would cost at a salvage yard?
Old 08-15-2009, 01:55 PM
Some of the 97's and 98's with the 5.4 had a E4OD. You do need to check the trans code on the door sticker.
Old 08-30-2009, 02:11 PM
homasi9251's Avatar
thanx for reply people but its the e40d
Old 08-30-2009, 10:04 PM
Thanks for letting us know the result. I knew my 94F1504x4 with 302 v8 had an E40D, but I didn't know they put that behind the 4.6.
glc evidently knows his stuff!!
Old 08-31-2009, 10:58 AM
They didn't, to the best of my knowledge.
Model: E4OD
Type: Electronic Four speed Over Drive
Years:
'89-'96 Bronco,
'89-'98 F-Series
Engines: {300, 302, 351w}, {460}, {7.3L IDI}, {7.3L PSD}, {5.4L}
Display: PRN(D)21 w/ overdrive lockout switch
Pan: 20 bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E
Model: 4R100
Type: Four speed, Rear wheel drive, and 100(x10)lbs of torque
Years:
'99-'01 F-150's (rare)
'99-'04 Lightning's, F-150 7700'
'99-'03 superdutys
'03-'04 gas superdutys
Engines: {5.4L, 6.8L}, {7.3L PSD}
Pan: 20bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E (gas), 9 (diesel)
Quick Reply: what kind of transfer case and transmission do i have
