Rear axle seal replacement...
Did a search. No luck.
2001 F150 SC with 5.4 and 153k miles. 9.7 diff (?).
I pulled my rear rotors to be turned last weekend and noticed rear end dope had leaked past the left side axle seal.
Anybody do a rear axle seal replacement? Any tip or tricks to pull the axles? Should I replace the outer axle bearings as well?
I've pulled the axles in my old Mustang 8.8 rear end. Is it similar?
Thanks!
Thanks!
This is a newer truck, but should be similar.
https://www.f150online.com/forums/ar...lots-pics.html
