2001 5.4L F150 with 8.8 rear end
Old 09-18-2009, 01:01 PM
ridemx's Avatar
So am I just misinformed but I thought 5.4's had the 9.75's? I started changing my rear axle shafts and realized it was an 8.8. Do they come with 8.8's from the factory? Or was the rear end replaced by the previous owner?
Old 09-18-2009, 01:11 PM
kingfish51's Avatar
How many bolts for the cover? If 12, it is an 9.75.
Old 09-18-2009, 03:21 PM
JimmysotherFORD's Avatar
if you have a 4r70w than it's most likely an 8.8. a 4r100 than a 9.75.
Old 09-18-2009, 10:15 PM
My 2000 F150Supercab 5.4L 4x4 had 9.75 rear and 4R70W. My current 2002 has a 4R70W. Haven't verifyed the rear but I'm sure it's a 9.75.
The 4r100 only came in the Lightnings I believe.
Old 09-18-2009, 11:09 PM
deerhunter7979's Avatar
The 4r100 came on the Lightnings AND the 7700 option as well as the snow plow option. It also came on all Eddie Bauer Expeditions.
Old 09-19-2009, 11:28 AM
I may be misinformed, but I thought all 5.4's came with 9.75's except in the 7700 and F-250LD, which had a 10.25.
Old 09-19-2009, 02:08 PM
Paralyzer's Avatar
that is true. if he has an 8.8 someone has done some swapping.
Old 09-22-2009, 04:13 PM
phil6608's Avatar
If it has the 8.8 then someone ether swapped in the 5.4 or swapped in the smaller rear!
5.4 came with 9.75 rear.
Phil
Old 09-23-2009, 04:12 PM
JMC's Avatar
JMC
JMC is offline
What is the 8th digit of your VIN? L,M,W or 6?
Old 09-28-2009, 12:41 PM
ridemx's Avatar
Ok, so its got 12 bolts on the case but I put new axle seals in and It took the 8.8 axle seal, the 9.75 was way to big? I'm stumped on what axle I have. Not sure of the vin but the axle code on the door sticker is H9 I'm pretty sure. Also, unless the clutch plates are completely gone its got no limited slip. Is there any way to tell by looking inside the case with the diff cover off?
Old 09-28-2009, 12:52 PM
kingfish51's Avatar
12 bolts = 9.75. Take a look at this thread too. https://www.f150online.com/forums/ot...-bearings.html
Old 09-28-2009, 01:45 PM
4.6 Punisher's Avatar
Round diff cover = 8.8
Sideways egg shape = 9.75
Old 09-28-2009, 02:27 PM
JMC's Avatar
JMC
JMC is offline
This article explains a lot about the 9.75. http://www.fourwheeler.com/techartic.../photo_17.html
Old 09-28-2009, 07:39 PM
brianscio's Avatar
I just copied and pasted this from my thread. Basically your truck has a 9.75 rear with a smaller style axle. The 8.8 bearings work fine since the axle is the same as the 8.8 axle but with 34 tooth spline. Hope it helps
OK, I think I solved it. Axle cost me $240 from ford cuz they were the only ones that had an answer. All of the other parts stores offer 1 axle for the 9.75 and for the 8.8.
The ford tech used my VIN and told me that the tag on the rear end (had i not tossed it) indicated 3.73 gear and 9.75 locking. Also, it said 923A which I guess is the code that says that I have one of the few trucks with a different axle and bearing setup. My trucks takes (driver side) a F75Z4234MB axle. This is identical to the 8.8 axle except it has a 34 tooth spline instead of 31. 99% of F150's with the 9.75 use a F75Z4234LB.
So, I hope this helps anyone with this problem in the future. If you have a 9.75" rear end and the replacment bearings are way too big and for some odd reason the 8.8 bearings fit.......you have the above axle. You didnt get the wrong parts, nobody swapped the motor or rear end when you weren't looking and my personal favorite.....Ford didn't throw in some old parts that they had laying around. For one reason or another ford used a smaller diameter axle on some 9.75 rears from 97-mid99. They switch to the other axle in mid 99.
Old 09-28-2009, 07:53 PM
Why does it appear that the OP has the same issue with an 01?
Quick Reply: 2001 5.4L F150 with 8.8 rear end
