how to hook up to dash lights!??!?! help please
Old 09-24-2009, 12:18 AM
thorherc67's Avatar
hey i am trying to install some stuff on my truck and wanted to install a switch to the dash lights so that it would light when the dash lights come on but i have no idea what to hook it up too. can anyone help?
Old 09-24-2009, 12:33 AM
ksandefer's Avatar
radio harness maybe?
I'm not positive this will work for what you want to hook up but there is an illumination wire on the wiring harness going to the radio. You may be able to tap into it to hook up what you want to correlate with the factory dash lighting. Just an idea.
Old 09-24-2009, 12:35 AM
thejake1989's Avatar
can you give some more details on what your trying to do
Old 09-24-2009, 12:45 AM
thorherc67's Avatar
i have a on board compressor that i have hooked up mostly and i am wanting to hook up the control to my lights because it has a light that i can hook up. it said to hook it up to a dash light.
i have taken apart the dash and have 4 free wires not hooked up a black, green, blue and brown one. can i use one of those?
Old 09-24-2009, 12:52 AM
are you just talking about a lighted switch for your compressor? like a light turns on when the switch is on and then off when the switch is off?
Old 09-24-2009, 12:57 AM
thorherc67's Avatar
its a control inside the truck that says the air pressure and has a switch that increases or decreases pressure. and it has a light that lights up the back ground.. i am wanting to hook that up
Old 09-24-2009, 12:59 AM
in that case id use the illumination wire from the back of the radio. should get you what you want. i think its the blue wire but dont quote me on that
Old 09-24-2009, 01:03 AM
thorherc67's Avatar
how would i get to it?
Old 09-24-2009, 01:04 AM
Your gonna have to take the radio out to get to it.
Old 09-24-2009, 01:06 AM
thorherc67's Avatar
damn... do you know what the four free wires are behind the dash?
Old 09-24-2009, 01:09 AM
thorherc67's Avatar
also do you know what fuse i can plug the compressor into? does it matter?
Old 09-24-2009, 01:13 AM
Don't know what those wires would be. It would probably be easiest to run an inline fuse and a relay
Old 09-24-2009, 01:15 AM
thorherc67's Avatar
where would i get that? and is there a specific type?
Old 09-24-2009, 01:32 AM
Inline fuses you can get at any autozone or radio shack and you can pick the size fuse needed.
Quick Reply: how to hook up to dash lights!??!?! help please
