Whats Wrong with my Floor Jack?
Old 10-25-2009, 07:17 PM
srfd44's Avatar
The jack only goes up so far under a load, then i can pump all I want, it won't go any higher. Its barley enought to get a wheel off the ground. It does not drift downward once the load is jacked up.
I tried to open the fill screw port to fill it with oil, but when I turned the screw a bit, oil started to come out, so I guess it is full.
Any ideas on whats wrong? or if this is fixable.
Old 10-25-2009, 07:29 PM
_cashel's Avatar
Not sure, but I've got a few jacks back in Ocala with this same problem, so I'm curious what the issue is and how to fix it.
Old 10-25-2009, 07:37 PM
We've had an MVP floor jack for about 18 years, and finally this past week it has been starting to do this. I better start looking for new floor jacks.
I think it is the hydraulic cylinder starting to go.
Old 10-25-2009, 08:02 PM
Tumba's Avatar
Look it up onilne by name and model number, and get the instruction book. It prabably just low of oil.
Old 10-25-2009, 08:04 PM
serotta's Avatar
Could be low on fluid, could just need a rebuild. If there's a good hydraulic place in your town it might be cheaper to rebuild it than to replace it with a new one. I had one rebuilt about 15 years ago and it's still working fine.
Quick Reply: Whats Wrong with my Floor Jack?
