ceter consol gear shift light not working
Old 11-07-2009, 10:50 AM
johnbaughman85's Avatar
i have an 04 lariat with the center consol gear shifter. the lights that are suppsoe to light up the park reverse drive and so on at night suddenly stopped working. can anyone help me out. i really dont want to have to take it to the dealer and pay out the *** for it to be fixed.
Old 11-07-2009, 10:54 AM
SSCULLY's Avatar
Try the bulb.
Thread in this forum, a few threads down from your thread at the moment.
https://www.f150online.com/forums/el...ion-light.html
Directions look correct, and straight forward in the thread, so you should be good to go, if it is the bulb.
Old 11-07-2009, 11:07 AM
thanks man u helped my out a lot
Old 11-07-2009, 06:39 PM
SSCULLY's Avatar
Thank LastSplash next time to run into him, he is the one that helped you
Old 02-27-2017, 09:08 PM
Will Bones's Avatar
I've got the same issue on a 2006 lariat crew cab. Replaced the bulb and still won't light up. Any other suggestions without paying out the a** to a dealership?
Old 02-28-2017, 07:41 PM
SSCULLY's Avatar
Time to get a meter and check for + VDC in the bulb socket with the main headlamp switch at least in the park position.
If you get + VDC using the bulb socket, your 2nd bulb was bad.
If you do not get +VDC, next try a different ground ( side wall of the cigar lighter; not the center pin ).
Quick Reply: ceter consol gear shift light not working
