Please Help Need pre-bent stainless steel brake lines
Old 12-02-2009, 06:11 PM
G Mc's Avatar
I am re-doing my truck and need to get ahold of pre-bent stainless steel brake lines and I can not find them for my yr (91) or make (4wd supercab)anywhere can someone please help.
Old 12-02-2009, 09:20 PM
SoonerTruck's Avatar
ummm, either go to a junk yard, or bend them yourself. They make cheap tools for this and you can buy long lengths of ss brake line and do it yourself. A flare tool is also used, but it seems like it might be over your head a bit. Junkyard is your best bet.
Old 12-03-2009, 01:28 AM
masseyman's Avatar
You can probably order them from www.inlinetube.com. Also try www.classictube.com.
Old 12-03-2009, 10:42 AM
G Mc's Avatar
Thanks for the help guys. I was trying to find pre-bent to save time but I went out and bought the line and I am just going to bend it myself on a weekend when I have off. Thanks again for the help.
Old 12-03-2009, 01:40 PM
ymeski's Avatar
I have tube bending springs that work well on aluminum & copper. The few times I attempted S.S. did not go that smoothly as the tensile strength is quite different. The way I was able to deal w/ that was to fill the tubing w/ sand before attempting the bend to prevent collapse during the bending process. Take your time. Multiple flexing's works better than "going for it!". You are simultaneously stretching & compressing the metal. A little torch preheating wouldn't hurt.
Old 12-04-2009, 07:39 PM
G Mc's Avatar
I finally got the old brake lines off of my truck and started mocking up the new lines. The bending is going slowly but surely. I'll try to post pics when I get it finished but it is looking pretty good so far. Thanks for all of the help.
Quick Reply: Please Help Need pre-bent stainless steel brake lines
