F-250 / Super Duty / Diesel
'94 F350 Brake Problems!!!
Old 12-21-2009, 09:21 PM
Nettershakes's Avatar
Exclamation '94 F350 Brake Problems!!!
My Buddy has a 1994 F350 5.8L, runs great but wont stop when you try to brake. We've replaced the booster and master cyl but the pedal still sinks straight to the floor barely able to stop the truck. Any ideas on what it could be? We're thinking something with vacuum pressure...
Old 12-22-2009, 12:03 AM
keith97xlt's Avatar
im gonna assume you went around a bled all the lines right?? keep bleeding them.. it might take a few times around. i replaced a the rear lines on my old 97 and it took 3 times around to get all the air out.
Old 12-22-2009, 12:11 AM
We did do it once and We are gonna do it again tommorrow. And then check all the hoses and lines for leaks. Thanks for the response.
Old 12-22-2009, 10:18 AM
powerstroke73's Avatar
You do know that you need to bench bleed the master right? If not you'll never purge the air. You can't just slap on the MC dry and expect it to work.
Old 12-23-2009, 08:46 PM
We did the bench bleed of the Master Cylinder and we bleed all the brakes a few times, and the pedal still goes straight to the floor. We are completely baffled right now.
Old 12-25-2009, 11:56 AM
bjp207's Avatar
theres air somewhere just going to take some time to get it out
Old 12-25-2009, 12:05 PM
f150fella08's Avatar
sounds like a leak or air still..ive done some brakes that i had to bleed them for about 30 minutes before they finally worked. did you adjust the rod?
Quick Reply: '94 F350 Brake Problems!!!
