That heater hose under the intake plenum
Old 01-03-2010, 11:26 PM
deltwith's Avatar
I just replaced the 4.6 Romeo motor in my '98 F150. One part that I had a hard time finding was the heater hose which runs from the rear of the water pump to the top, rear of the passenger-side head.
I found that on my original (98) romeo 4.6, the hose was completely metal and attached to the 'nipple' (short tube) coming out of the rear of the water-pump. This was sealed with two o-rings.
My replacement motor, '97 4.6 romeo, has a different style 'nipple' and hose. This hose has more bends and connects with a short section of flex hose and a clamp. This style is apparently less common.
If you have the style with the flex hose and clamp, you can purchase a replacement. Ford part number F65Z18472FC. This part retails for $79.
If you would like to change to the solid metal line, you can buy the o-ring style 'nipple'. Ford part number F75Z8555AA. Retail $10. Don't forget the o-rings, part # W704593S100. Retail $12.80 EACH!!! You'll need 2.
If you need to replace the solid metal line, you'll need part number F65Z18663FB. Retail is $20.
Most likely, if you're working on this, you'll also need the EGR line from the exhaust to the EGR valve. This is part number F65Z9D477B. Retail is $73.
Pictures:
http://i663.photobucket.com/albums/u...231024x768.jpg
http://i663.photobucket.com/albums/u...361024x768.jpg
http://i663.photobucket.com/albums/u...241024x768.jpg
Of all these parts, the EGR line is the only one I know of which can be purchased somewhere other than the dealership. The o-rings can be located elsewhere. I didn't get dimensions, but I would hope they are a standard size. If you have to purchase parts from the dealer, I would recommend being nice and leveraging for a discount. *hint*
Thanks for everyone's help. I'm just trying to give a little back. I in no way intend for this to be an advertisement for dealer's parts department. I wish I could have found a write up like this to save me from staring at drawing with the parts guy and losing days of waiting on parts that weren't right. Good luck on your projects!
Quick Reply: That heater hose under the intake plenum
