3/4 ton coil springs on 150
Old 01-15-2010, 12:40 AM
5.04x4's Avatar
hey i was just wondering if anyones done this to their truck. i got a 93 150 independent 4x4. does anyone know if i go out to a junkyard and get some coil springs off a f250 will they fit on my 150 and will they lift it any or will it just be a rougher ride? im just trying to level it out the cheapest way possible
Old 01-15-2010, 12:46 AM
Paralyzer's Avatar
The TTB front end cant really be lifted without a proper lift that relocates the axle pivots ect..any lift the the front of a TTB front end gives you positive camber. Sometimes its can be brought back to specs with alighnment slugs if you go no more the 1-1.5 inches. But thats SOMETIMES.
Old 01-15-2010, 07:11 AM
S-crew03's Avatar
Look at leveling kits that just relace the front coils and shocks. Pretty inexpensive, and only lift the front end 1-1.5 inches. There is another thread here somewhere that shows the "lift".
found it...
https://www.f150online.com/forums/pr...lled-pics.html
Old 01-15-2010, 07:27 AM
aswaff400's Avatar
i dont think ive ever seen a 4x4 f250 ttb with coil springs. dont they use leaf springs up front?
Old 01-15-2010, 06:14 PM
Paralyzer's Avatar
im pretty sure your right on that
Old 01-15-2010, 06:56 PM
aswaff400's Avatar
i believe coil springs didnt start coming around in the 3/4-1 ton trucks till about 2005 unless its a 2wd. then yes they have coil springs, but im not sure if they will fit. just get some level springs or spacers...
Old 01-15-2010, 10:00 PM
Beastly_95's Avatar
i have seen a 4x4 3/4 ttb WITH coils before...
i found it exremely odd but ive seen it
Old 01-16-2010, 05:45 AM
andrew_516's Avatar
there are some out. my friends dad used to own a 94 f250 with some.
Old 01-17-2010, 01:48 PM
5.04x4's Avatar
thanks for the replys. i thought the 250s came with coils and the 350s had leafs but i was wrong i just did my research. i already tried the spring spacers but got about 1/2 an inch lift. i guess i'll just save up and go with the leveling kit. problem is im a full time student and work part time for minimum wage.
Old 01-17-2010, 07:56 PM
bpm4x4's Avatar
F250 2wd has coils on the front, most 4wd f250's are leaf spring (our era of trucks)
Old 01-17-2010, 10:33 PM
5.04x4's Avatar
would these coils fit my f150? and if so what difference would they make?
Old 01-18-2010, 06:14 PM
powerstroke73's Avatar
Aside from lowering it they would most likely ride rough as they're made to hold up a 1000lb engine.
If there is an F250 with coils and a 4x4 TTB out there it isn't factory. Ford never built it with anything but leaves. More than likely someone stuck F250 badges on it and/or put wheel adapters on an F150.
Old 01-18-2010, 06:31 PM
the newer trucks are coil up front on the 4X4's
Old 01-18-2010, 11:45 PM
bpm4x4's Avatar
Really?????
Quick Reply: 3/4 ton coil springs on 150
