Amp Under the Dash ? Is it Doable ?
Old 02-02-2010, 05:51 PM
locorider's Avatar
I was wondering if anyone has mounted an amp under the dash. It just seems that it will be very convienent sicne all the wiring etc is right there.
I have an Alpine MRP-F450 that has speaker and pre-amp level inputs.
I was thinking of using the speaker level inputs on the AMP with the stock HU and using the stock speaker wiring but upgrading the speakers to 5X7 Alpine Type R's.
Anyone have the amp under the dash ?
Edit* This is on a 2010 F150 Screw
Old 02-02-2010, 05:58 PM
JJDH's Avatar
news to me
Old 02-02-2010, 11:51 PM
Sundevil2188's Avatar
theres another thread in the speakers and subs section that another guy is talking about doing it, but ive never seen it done before. Not worth the time/hassle to try and fit something that large in there and still have it be clean wiring and good connections. Put it on the back wall and call it a day.
Old 02-03-2010, 01:32 PM
Under Dog's Avatar
Not to mention the amount of heat an amp can create, would be bad news with all the under dash wiring.
Old 03-01-2010, 02:30 AM
hunterjh's Avatar
Yeah i had a 4channel Rockford Fosgate mounted under my dash on the transmission hump....it worked fine and was convienent ...i ended up takin it out and placing it somewhere else because it got in the way during hunting season
Old 03-01-2010, 02:44 AM
GreenBuck50's Avatar
x2, mine in the green truck would get hot.
Old 03-04-2010, 07:38 PM
BlackFX4inTN's Avatar
I had a JL 250/1 in the dash until I figured out how to get the backseat off. Then I relocated everything back there. In order to make a hole large enough to fit it in there, you have to take the stereo and everything else out down from there, including the ashtray. But then again, I dont know how large that amp is that you have. The amp will get scratched up though and it's really not worth it. Put it on the back wall.
Old 03-04-2010, 07:48 PM
fine_style150's Avatar
sounds like a big hassle save the time and put ur audio in the back wall, i have officially 3 amps behind my back seat
Old 03-04-2010, 08:14 PM
JJDH's Avatar
The new jl xd amps are so small they would fit in the glovebox..
Old 03-04-2010, 08:29 PM
mSaLL150's Avatar
x2 I was just going to say this. I saw one the other day, the thing was barely bigger than my hand! And packin some good power. I would not be surprised if you fit it under the dash with no problem.
Old 03-04-2010, 08:36 PM
JJDH's Avatar
Yep. they are simply amazing. I was at the store and said what the hell is that.... Couldnt believe it.
Quick Reply: Amp Under the Dash ? Is it Doable ?
