Turn signals not working in my f150
Old 02-04-2010, 08:52 PM
dobrienj's Avatar
My turn signals do not work all the time. Is there a flasher switch like there used to be in older cars? I just get a fast clicking noise from both signals.
Old 02-05-2010, 07:58 AM
SSCULLY's Avatar
Yes there is a flasher.
do the hazards work when the turn signals do not work ?
Can you post some info on your truck, or complete your profile.
Old 02-05-2010, 12:46 PM
thill's Avatar
ok my blinkers also do not work. the hazards DO work but the blinkers do not. however, if the brake is applied and i move the blinnker lever in a certain direction the blinker arrow does light up but it only stays lit
Old 02-05-2010, 02:13 PM
SSCULLY's Avatar
Old 02-06-2010, 08:16 PM
dobrienj's Avatar
I have a 1999 ford f150 styleside extended cab pickup., with a 4.6 liter v-8. The flashers work fine but the turn signals do not. I've replaced the switches in older cars when they were near the fuse box. not sure where it is located now. It doesn't matter what position the tilt stearing wheel is in.
Old 02-06-2010, 08:32 PM
SSCULLY's Avatar
For your 99 MY, take a look at this thread
https://www.f150online.com/forums/el...l-lowered.html
It shows the connector that could be pulled apart, causing the turn signals not to flash.
This is the easy 1st check, could be the MFS, which is the next thing to check ( I am guessing it is the MFS, but don't want to send you on a wild goose chase ).
The flasher is the same for both the hazards and the turn signals, so it is not that.
Quick Reply: Turn signals not working in my f150
