EZdown tailgate assist
I just got my DeeZee EZdown tailgate assist and installed it. Has anyone else had a problem with the retaining spring clip on the gas shock coming loose or falling off? At first I thought one of the clamping tabs on mine had broken off but now I'm not so sure.
Can some one post some closeup photos of theirs so I can see if it looks like the one I have? I have photos of mine in my photo gallery.
Follow up & Heads Up
I talked with a Customer Service rep at DeeZee this morning. Apparently the spring clip is supposed to look like the one I have in the photo, with only one clamping tab. They must either have the sping clips formed around the gas shock after they receive them or snap them on themselves. They saw my photo and said it looked like mine was 'stretched' and that they would just send me a new assembly today. Apparently you need to be careful handling it so as not to pull on the spring clip very hard or it'll just pop off. Once it comes off it has stretched enough that it won't stay on anymore. They said I didn't even have to return the old one so I may have a chance to make an improvement to it and keep it for a spare. I'm thinking I can just drill a hole through the clip and shock and pop rivet them together or tap the shock and put a small screw through it. Yeah I know .... that's what they make duct tape for also
Can't beat their Customer Service.
Also, I noticed that my tailgate, with the integrated step, assist pole and camera, drops a little faster than the one in their online video and I suspect it's because of the heavier tailgate on the Platinum, so they may wear out faster.
I can't remember if I read it on their website, or where, that they specifically mention NOT to use one on both sides. Don't ask why, I just read that. I haven't checked but do these tailgates just lift right off like the old ones? I think that may have been the reason that with two of them the tailgate may have a tendancy to lift up off the pivot hinge.
Mine hasn't fallen off yet either but I notice that when you close the tailgate the end of the gas shock lifts up to the position where it could fall off. As soon as I get my new one I'm going to see if I can drill a hole through the one I have now and pop rivet the spring clamp to it. It's probably going to be tricky drilling a hole through that thin spring stock.
