Need Help with egr valve to exhaust manifold tube
Old 02-10-2010, 11:25 PM
aatkins08's Avatar
I thought I just had a donut gasket leaking but after some checking the tube that connects my exhaust manifold to my egr valve is broke right at the exhaust manifold. I couldn't see it real well it was already dark out and I needed a better light. How hard and expensive is this tube to replace, and this is a probably a stupid question, but does it need replacing, or could I just plug it off at the exhaust manifold?
Old 02-11-2010, 06:17 PM
DYNOTECH's Avatar
I would replace it. You have two vacum lines that connect to the tube and the DPFE and there is an orfice in the tube between both hoses. I was told the tube was a dealer only item, they wanted $75.00 for it. A buddy said he got his for $50.00 from a dealer. The small fitting that's attached to the exhaust manifold is probably rusted on pretty good so getting the tube off the fitting may be a pain. It can get to be a big job if you have to remove the exhaust manifold, all depends on how bad everything is rusted up. I ended up installing a new manifold, fitting, and tube on mine. Removing it from the EGR is the easy part. Good luck
Old 02-11-2010, 09:54 PM
PFA's Avatar
PFA
PFA is offline
I too am having this issue. I checked online with Murrays and Autozone...no body has it in stock, or in their warehouses. I did a search for the Dorman brand part number (as listed with both above places) Dorman 598-107 for my application, and I bought it for like $29 through Amazon... plus shipping. Now, it only took a few days to get it. I have a different exhaust manifold with good thread in the manifold. Problem is, the fittings on either end don't fit the hole on the manifold. It is like there is another piece that screws into the manifold, larger piece, but I don't know what it is.... Any ideas?
Old 02-11-2010, 09:59 PM
aatkins08's Avatar
Well I tore part way into mine tonight, got the fenderwell off so I could get a better look at it. Looks like somebody before me had the same problem but decided to fix it with a whole lot of jb weld. I'll give them credit though its held for 7 years, and about 70,000 miles. So it is either back with the jb weld to see if it will hold again, or replace the exhaust manifold, and the egr tube
Old 02-12-2010, 08:01 AM
PFA's Avatar
PFA
PFA is offline
Something simular happened to mine, before I had it. It looks to be all welded up. But I don't have anywhere to bolt the new tube to. There must be an adapter just below the tube going to the ex. manifold. I guess I will check with a dealer on it...
Old 02-12-2010, 08:31 AM
shifty_85's Avatar
you coluld MIG weld it im pretty sure that tube is steel. if i still had my EGR tube id send it for free.
i took mine off and tuned to have EGR pluged.
Old 02-12-2010, 09:47 PM
PFA's Avatar
PFA
PFA is offline
The dealer can get it..like $35. Two male ends, different sizes. Trying to find one in aftermarket...it has to be available....or make it up.
Does anyone know exactly how long this piece is, between the exh. manifold and the tube?
Old 02-13-2010, 02:43 AM
jbrew's Avatar
The adapter is a dealership/ scrapyard item only -
Quick Reply: Need Help with egr valve to exhaust manifold tube
