F-250 / Super Duty / Diesel
DPF delete kit questions...
Old 05-30-2010, 05:27 PM
04procompLARIAT's Avatar
... I am absolutely FED up with only getting around 10mpg's! I am very interested in the DPF delete kit but, I do have a couple questions for those who have completed this mod. Thanks in advance.
One... I live in CA, anyone else live in CA that has done this mod? I am curious on the fine if I get caught without the filter on my truck.
Two... Is it even worth doing? I figure it'll cost around a thousand smackers to do this. What mileage are you guys seeing major improvements in MPG's and power?
Three...are there more cost effective mods I can do to get better MPG's? If I were to re-gear and slap an Intake and exhaust system would I see major improvement?
Old 05-30-2010, 07:16 PM
powerstroke73's Avatar
1. Expensive, and is federal not just CA. Who do you think imposed the emissions requirements on the mfgs? Some states are simply enforcing what has been the law for a long time.
2. It depends if you're willing to chance paying for a more expensive repair out of pocket since your warranty is going out the window.
3. Most likely not any major increases.
Bottom line, you bought a large truck and then lifted it sky high with big tires. What else were you expecting? If you are that concerned with mpgs then sell the truck and get something more economical and leave it stock. You're looking at maybe 5mpg difference and I doubt you'd even see that much. I'd leave it stock until the warranty is up since repairs to that engine are costly. Once the warranty is gone then I'd think about it. The biggest key to keeping the fuel numbers up on the 6.4L is keeping the rpms down and running as unloaded as possible. Both are hard to do with that engine, and your lift/tires makes it even harder. I've heard of guys getting near 20mpg in stock form with the dpf delete.
Old 05-30-2010, 07:48 PM
GreenBuck50's Avatar
Been driving full sizers for years... cost of the game.
Old 05-30-2010, 08:09 PM
FX4life's Avatar
Regearing would probably help some
On my gasser I never saw an increase in MPG's with an intake and exhaust even when those were my only mods, definitely never saw an increase after custom tuning either... Sorry I can't say for diesels though I have heard good things about the DPF delete and spartan tunes..
I wouldn't really worry about getting caught, just keep it and put it back on for inspections. How would they catch you on an everyday basis anyway? I know they are strict in CA but geez pulling you over just to check the exhaust
Old 05-30-2010, 11:56 PM
Stroked05's Avatar
I would talk to innovative diesel. Check out thier website, IIRC you will have to sign a waiver for anykind of deleting you do stating you know the modifactions made to the truck make it illegal for street use.
Old 05-31-2010, 10:35 AM
FL4X4's Avatar
I live in florida so I've never had to deal with any emissions law BS so I can't really give you any input on that. But I will tell you that if you just run a straight pipe and proper tuning(SCT/Spartan) you WILL see DRASTIC power gains and improved mpg. And like every one has already mentioned, can't really buy a 8000lbs crew cab 4x4 and and lift it then expect to get good mpg.
Old 06-01-2010, 02:51 AM
Im not expecting good mileage! I just want medeocre gas mileage!! Diesels are easily capable of getting 15+ mpgs!
Old 06-01-2010, 01:43 PM
dav700's Avatar
I've done the delete with a spartan on a f350. Mileage went up to an average on 16 and thats driving the hell out of it. Well worth it, main thing is you have to be careful about blowing smoke. Running a bottle of fuel booster helps cut down on the smoke.
Old 06-01-2010, 05:40 PM
SFCFX4's Avatar
New ones are, when they're left stock. But you shouldn't expect that when you lift it and put huge tires on it. I just came back to Dallas from Arkansas and got 15+ with a load in the back, completely stock.
Old 06-04-2010, 04:30 PM
crazynip's Avatar
THIS
What the hell did you expect? Want good gas mileage go buy your *** a prius
Old 06-07-2010, 07:43 PM
Originally Posted by crazynip
THIS
Im not concerned with what I am getting as far as mileage. I just know there are ways to make it a LOT better and I was wondering what the pros and cons of the mods are.
Old 06-07-2010, 07:50 PM
BrizzleOrizzle's Avatar
wait till the high pressure fuel pump goes out and ford denies the warranty. you have to rebuild the whole fuel system because of metal contamination and sometimes it hangs an injector open and blows a rod out the side. seen it several times.
Old 06-08-2010, 12:47 AM
Can't have everything, man.
Old 06-29-2010, 11:22 AM
HighOn22's's Avatar
How about you trade trucks w/ me.
I have a gas and get 12.5 in town and 14 on highway. I need to regear, but that will only help fuel millage.
Old 06-29-2010, 06:28 PM
Haha... I can have everything damnit! Yea I understand the fact ill never be a gas saver. BUT, is it possible to swap in the new 11's exhaust system into our trucks?
Quick Reply: DPF delete kit questions...
