Rear brake (drums) shoe replacement help.
Old 05-31-2010, 05:32 AM
mcolford's Avatar
Im gonna take on the task of replacing the rear brakes on my 98 F150 (4x4, 4.6L if it matters). Its got the good ol' fashioned drum/shoes combo. Any special tools needed ? Also if anyone has a condensed version of a how-to it would be appreciated.
-Matt
Old 05-31-2010, 11:01 AM
illness95's Avatar
i never really used any special tools.. unless u consider a pair of vise grips and pliers special...i remember it taking like an hour or so to figure out one side, then it took like 20 mins for the other side.. lol
disassemble one side at a time so u always have a reference, incase u forget where things go
Old 05-31-2010, 12:13 PM
jgger's Avatar
Get the brake spring tool. I know a kid who did a set with pliers and broke a tooth !
Old 05-31-2010, 05:20 PM
maddoughboy's Avatar
I would deffently get the speacial tool to do it, it makes it so much easier, but you don't have tohave it.
Old 05-31-2010, 05:52 PM
Cetansapa's Avatar
I used to do it with just a couple screwdrivers..........
Old 05-31-2010, 06:26 PM
jbrew's Avatar
I just use my fingers,- wimps.
Old 05-31-2010, 09:36 PM
Cetansapa's Avatar
You da MAN!! Name:  party.gif
Old 05-31-2010, 09:49 PM
MmmBuckles's Avatar
ya. spring tool would help alot. i used a pair of pliers and it was a pain. overall not too hard though.
Old 05-31-2010, 10:06 PM
jbrew's Avatar
Originally Posted by Cetansapa
You da MAN!!
Yes sir
Seriously , I use a nut driver, compress/ spin the cap/ pops off. Might be sticky at first, but you can get it that way.
mcolford - If you get lost, I have some good pics and diagrams, - no worry's.
Old 05-31-2010, 10:27 PM
mcolford's Avatar
Got er done this evening. Spring tool and the other socket looking device and it went ok... other than a cracked knuckle due to slippage, haha. Thanks guys!
-Matt
Old 11-16-2010, 09:06 PM
rockercar's Avatar
Are there any special tools required in brake drum replacement? I have a leaky rubber seal in my wheel cylinder, so I am going to replace the shoes and wheel cylinder.
Any suggestions? I would appreciate it.
Old 11-16-2010, 11:41 PM
Do one side at a time, make sure you get the shoes on right (their are two differnt ones,) and their are tools out their that will make it easier but you don't have to have them pliers and screw dirve work
Old 12-22-2010, 04:17 PM
mcline86's Avatar
Quick question here, I have never done a drum brake change before but i like to try things myself first.
Im not sure if the rear drum brakes are gone in my truck, sometimes it seems to stop "alright" and then sometimes u press the pedal about halfway in and doesnt do much. then you press it a little more and the truck nose dives and grabs hard.
My first thought was that its relying on front brakes only to stop the truck and it needs new rear shoes or something??
Old 12-22-2010, 08:53 PM
piston91's Avatar
My best advice, get a couple good pictures of it cleaned before you dismantle it. It makes assembly alot easier then you arent second guessing you work.
Old 12-23-2010, 06:05 AM
adrianspeeder's Avatar
Nothing magical about working on drum brakes, they been in use since 19****ity2. Easiest way to check is jack up a rear tire on a stand, get it spinning by hand, and have a helper hit the brakes.
Adrianspeeder
Quick Reply: Rear brake (drums) shoe replacement help.
