Torque Specs
Old 06-23-2010, 11:40 PM
tdel10's Avatar
Torque Specs
I'd like to start a list of different torque specs for common jobs. If anyone knows, or has a Ford tech manual...post 'em up! You know we'll all eventually need them!
Wheels:
Lugnuts -
Brakes:
Caliper bolts -
Carrier bolts-
Engine:
Oil drain plug -
Spark plugs -
Oil pan -
Suspension :
Spring cup(top) -
Control arm bolts -
Balljoint -
U-bolts(nuts)-
Spring shackle -
Drivetrain:
Diff cover:
Front-
Rear-
Transmission pan -
This is obviously just a basic list, with room for expansion. Only post figures you know are 100% correct, and I'll edit as needed. If this goes well, maybe we can put together an FAQ or a Quick Reference Guide....add this to it and make it a sticky at the top of the page or in the tech section.
Old 06-24-2010, 01:55 AM
jetech00001's Avatar
lug nuts torque is in owners manual 150 ft lbs
Old 06-24-2010, 03:12 AM
ajaj's Avatar
Torque Tip
Keep tightening..........when you feel it start to get loose again.......STOP!
its good then!
Old 06-24-2010, 09:01 PM
d4studmuf1n's Avatar
Brake caliper anchor plate bolts: 185 nm 136 lb-ft
Brake caliper bleeder screw: 20nm 177 lb-in
Brake caliper flow bolt: 40 nm 30 lb-ft
Brake caliper guide pin bolt: 74 nm 55 lb-ft
Brake disc shield bolts: 18nm 159 lb-ft
Brake flexible hose to frame bracket bolt: 17 nm 150 lb-in
Brake flexible hose bracket to spindle: 30 nm 22 ft-lb
Brake tube fitting: 17 nm 150 lb-in
Old 06-24-2010, 09:08 PM
Oil pan
Tighten the bolts in the sequence shown in 3 stages.
- Stage 1: Tighten to 2 Nm (18 lb-in)
- Stage 2: Tighten to 20 Nm (177 lb-in)
- Stage 3: Tighten an additional 60 degrees
Ignition coil: 6 nm 53 lb-in
Spark plug: 12nm 106 lb-in
Spark plug gap: 1.05 +/- .05 mm
Engine oil drain plug: 23 nm 17 lb-ft
Old 06-24-2010, 09:14 PM
Transmission oil pan
4R70E/4R75E: 14 nm 124 lb-in
6R80:12 nm 106 lb-in
Old 06-24-2010, 09:21 PM
8.8-Inch Ring Gear
9.75-Inch Ring Gear
Old 06-24-2010, 09:27 PM
Front Suspension
Well i think thats everything if you got any other specs you want hit me up
Old 06-24-2010, 10:36 PM
f150fella08's Avatar
Old 06-25-2010, 09:46 AM
tdel10's Avatar
Wow. Awesome, thanks!
Old 06-27-2010, 09:59 PM
no problem! honestly if you have any other torque specs that you need ask away...
Old 07-30-2010, 10:17 AM
dougfreitag7's Avatar
Not sure if this was answered above and I just don't know the correct terminology, but do you have the torque specs for the rear leaf springs and shackles?
Old 08-01-2010, 03:04 PM
both bolts on the shackle 148 ft-lbs
13. Tighten the U-bolt nuts in 4 stages.
o Stage 1: Tighten in a cross pattern to 35 Nm (26 lb-ft).
o Stage 2: Tighten in a cross pattern to 70 Nm (52 lb-ft).
o Stage 3: Tighten in a cross pattern to 100 Nm (74 lb-ft).
o Stage 4: Tighten in a cross pattern to 133 Nm (98 lb-ft).
Old 10-31-2010, 01:43 AM
mixedbreed's Avatar
This includes the rear shackle to frame bolt? Basically the 3 bolts that hold the leaf to the frame are the same? Been having a issue with mine and suspect the bolts are not torqued as much as they should be.
Old 02-23-2014, 03:45 PM
Buck268's Avatar
Anybody have the spark plug torque specs for a 5.0 Coyote?
Edit: Looks like these 5.0L take 124in-lbs.
Quick Reply: Torque Specs
