expedition overhead trip computer inF50?
Old 03-10-2001, 08:14 PM
turbo497's Avatar
Post expedition overhead trip computer inF50?
I am looking at the wiring diags on a 2000 expedition and see that this module should work in a f150 with harness modifacations, has anyone sucessfully done this swap yet. and if anyone has the computer would you sell it to me.
I've already put in door keypad,will put in autolamps, and looking to do electronic climate control
Old 03-10-2001, 11:17 PM
turbo497's Avatar
Cool
well here goes for anyone who is technically cabable this is the splice schedule for the C928 connector that plugs into the OTC computer( this is the one with range, MPG, gallons in tank, and compass.
Pin#1 NOT USED
Pin#2 CKT702(WH/BK) splice to c905 pin#4
Pin#3 CKT703(WH/OR) splice to c905 pin#3
pin#4 CKT 71(OG/LG) splice to c174 pin#43
pin#5 CKT679(GY/BK) splice to c157 pin#3
Pin#6 NOT USED
Pin#7 CKT 53(BK/LB) splice to C242 pin#20
Pin#8 CKT434(LB/BK) splice to c283 pin#4
Pin#9 CKT705(LG/OG) Splice to c243 pin#32
Pin#10 Not used
Pin#11 not used
Pin#12 CKT729(RD/WH) splice to c283 pin#6
Pin#13 CKT875(BK/LB) splice to C905 pin#1
pin#14 ckt1003(GY/YE) SPLICE TO C905 PIN#2
PIN#15 CKT29 (YE/WH) SPLICE TO C237 PIN#3
PIN#16 CKT204 MARKED AS GROUND SPLICE TO GROUND?????
PIN#18 RIGHT MAP INTERIOR FEED CKT403(LG/VT) C245 PIN#2?????? OR C242 PIN#22
PIN 19 SAME AS 18 ONE FOR LEFT AND ONE FOR RIGHT.
PIN#20 NOT USED
The wire colors to the coresponding splice schedule match the colors listed off C928 If you start project and wires are not the same please email and I'll check diags again
It looks like this module does not handle the outside temp from the ambient temp sensor in the front grille of the truck. it looks like it is moved into the electronic climate control module. right now my over head module has compass and temperature on I may want to run both modules in tandem until I install electronic climate control
Old 06-28-2001, 12:47 AM
SilverFlareSide's Avatar
Question
What all would be needed to do this mod? I already have the overhead console with temp and compass, does it require another computer to do the other things, or is it already there waiting to be wired?
Old 01-10-2010, 03:18 AM
Ace_boy2099's Avatar
I was informed of this upon asking in other threads on this site to findout about doing this and by the sound of it IF I do this which i wish i could, (I would LOVE to have the MTE, MPG, Temp, and Orientation on an overhead console in my f150) would take ALOT of work including pulling alot of the dash apart and running wires ALL OVER THE PLACE. Not only would I have a HUGE project ahead of me if I was to try this, but I don't have the luxury of parking it for a week or so so I can rip the whole thing apart and get everything wired up. and sounds like I would have to "Flash" the ECU to tell the OTC what size fuel tank i have, Of which I don't even know.
The site I was informed of is:
http://www.ford-trucks.com/forums/10...nstall-qs.html
Quick Reply: expedition overhead trip computer inF50?
