DDM tuning HID wiring diagram for 9007 heads..
Old 08-13-2010, 11:32 AM
Uncle Jesse's Avatar
Anyone have a wiring diagram for how to install the kit? I bought the hi/lo kit with the slim ballasts.. received everything but no instructions.. i went to their web site and pulled up a few different diagrams, just want to make sure i have it all laid out correctly..
Anyone have any experiance with this set up?
Thanks in advance..
Old 08-13-2010, 01:32 PM
W.L.B's Avatar
Did you get the harness? If so there is one wire with a inline fuse, that goes to the battery. There is another short wire with a bolt connector that needs to go to a ground, make sure its a good solid ground. There is going to be one wire with a 9007 connector on it. That needs to connect to the stock harness, but only one side needs to be connected. The passenger side stock harness is unused.
Old 08-13-2010, 01:46 PM
Yep, i got the harness with it. Just would have been real nifty if they had sent a wiring diagram... i am an engineer type and i lke pretty pictures to follow...
Quick Reply: DDM tuning HID wiring diagram for 9007 heads..
